Hi there,
I just joined the forum being interested in the bike lights.
Somebody says:
low = 0.280 amps = 2 Watt
med = 0.960 amps = 7.1 Watt
hi = 1.40 amps = 10.36 Watt
boost 1.85 amps = 13.7 Watt
At these power levels at input, with 88% efficiency on the driver it turns to a max of 12 Watt on the LEDs. This means 1200 lumens at most. Remember that Magicshine 880 really draws ~20Watt from the battery, for a max of 1600-1700 lumens. This light has the ability to output 2000 lumens based on the LEDs spec, but seems to be far from that, and the reason is heat dissipation. It’s too small to dissipate the 80% of power turned into heat (at max setting about 11.3 Watt is heat, 9.6 Watt from the LEDs and 1.7 Watt from the driver). Anyways, looks like a good and compact light. Maybe with some tweaking (current limit increased little) it can output more, like 1600 lumens.
