*sighs* The bike build is going slowly, I’ve already had Phoenix Cycleworks fix two of my four issues. I’m sure it’s been mentioned on here before, but I can’t find it, but the NS RAG+ has 20mm direct mount spacing for the rear brake caliper. The GRX BL-RX810-L lever and caliper come with Brake caliper mounting bolt C length of 38 mm, so I need the 33 mm length bolts. Found some online for £6.99 each, or via Taiwan so no good for a test ride tomorrow.
Can I just shovel any old M4 (I think they’re M4) bolt of the correct length in there, or does it need to be made of a particular metal…?
Oh FFS! Just bodged it temporarily with a couple of nuts to take up the slack, but it turns out that the 160mm rotors don’t fit, so I need yet another adapter. 🤬 Anyone know where I can get a Shimano Rear Mount Adaptor Flat to Flat Road SM-MA-R160 D/D from?
