Home Forums Chat Forum Semi urgent stuck in Corfu VW T4 van wont start.. Help!!
Viewing 26 posts - 1 through 26 (of 26 total)
  • Semi urgent stuck in Corfu VW T4 van wont start.. Help!!
  • cloudnine
    Just had a call from my dad and he’s stuck by a remote beach in Corfu.
    Its a 1999 2.5tdi VW T4 german coach built camper.
    The van turns over but wont fire at all.
    Mentioned that it has gotten worse at starting the last few days.
    Could anyone suggest where to start (yes it has fuel in it).
    My first thought was dodgy fuel..
    hammyuk
    If its petrol – check points/dizzy/rotor/coil
    Houns
    If it was me I’d………..
    Not give a toss it can’t start, open a beer
    cloudnine
    Its a 2.5 tdi turbo diesel. Apart from removing pip from fuel filter to engine (to check there is fuel going to engine).. Anything else checkable?? He probably has tools and a multimeter. Houns.. thats what he’s probably done but at some point needs to make a few island hops to get a ferry from greece to Italy on the 11th october
    allthepies
    Phone the breakdown service.
    He does have breakdown cover presumably ?
    StuF
    glow plugs?
    Pigface
    Will it bump start?
    Stoner
    it will start without glowpplugs. I have the same van/engine.
    Unfortunately I have no experience of it a breakdown as mine has been faultless for 120,000 miles. I know that doesnt really help him 🙂
    Is there a fuel shut off solenoid sticking closed perhaps?
    Or as above, fuel filter blocked/full of water. I wouldnt be surprised, some diesel on the continent can be absolute junk.
    mcmoonter
    Perished fuel filter O ring, allowing air into the system? If there are clear hoses to the injector pump you will see bubbles.
    Flaperon
    Might still be the glow-plugs – just because you don’t need to wait for the light to go out doesn’t mean they’re not needed to assist the start.
    When they fail you can get by with just one cylinder firing and dragging the rest of the engine into life. Check for continuity across the terminals.
    Might also be a pump in the fuel tank, can he park it anywhere facing downhill?
    cbike
    A battery beginning to fail? I have had two vans with those symptoms and and a car and they were solved with new battery. It may turn over but you do need some oomph for a diesel. Sounds like sitting for a bit on holiday may have accelerated battery failure.. Try a jump start or pull start with another van.
    nasher
    ditto battery
    also does it have electronic ignition with immobilser? any lights on the dash?
    cloudnine
    Thanks for the replies.. i have forwarded some suggestions.
    z1ppy
    Can he hear the fuel pump prime when he turn’s the ignition on? (before turning over)
    Had intermittent starting issues with my VAG due to the tank pump.
    hora
    Last qeek my 08 car just wouldnt do anything. No central locking, lights, no clicking noise indicative of a flat battery. 200miles driven the day before too. New battery = bingo!
    robfury
    If it turns over but not starts fuel system issue. Try fuse for fuel pump first. Then check fuel pump working by removing a fuel line. Will have to reprime system after that. If it’s none of those either leaking fuel pipe letting air into the system or knackered injector.
    My money would be on fuel pump has died or blocked injector
    Suggsey
    Sat in the heat fuel cavitation caused by it sucking air into the filter hence its been getting worse. Get him to check the air bleed bolt on top of the fuel filter housing Is done up. Had it happen once with identical symptoms on a Tdi passat….I had forgotten to nip the bleed bolt tight after a service and it slowly sucked air in. Also second choice would be battery again caused by heat drying a cell out.
    andyl
    does he have a leisure battery he can try?
    Blazin-saddles
    Having had a T4 crank over endlessly (until flat battery) I’d have suggested glow plugs too, but usually only manifests itself when cold??
    Muke
    +1
    cloudnine
    The battery isnt flat. He tried about 8 times to start it then decided it was unlikely to start. Fuel was definitely (or supposed to be) diesel and was filled about 100 kms before the problems started. Ive given him a list of fuses to check and suggestions from here. Luckily they are ‘stuck’ at quite a nice part of Corfu called dassia.. with cold beers in the fridge, ample supply of food and several bikes on the rack. In fact im quite envious of such an awful predicament.
    porter_jamie
    Pull the fuse box cover and find the glowplug relay and the ecu one. Put your finger on it to see if it clicks. If its the ecu one it’s probably a wire in the engine bay. You can jury rig it with a bit of wirr to switch on the relay. Happened to me at the airport. Aa man and a mate on the phone diagnosed it. You need to call the aa or equivalent
    Matt_SS_xc
    Don’t kn
    Matt_SS_xc
    Don’t know if it helps but our peugeot van did just that and it was the immobiliser fuse
    nickjb
    Friends t4 got stuck once and that was the immobiliser. Took him ages to find it.
    cloudnine
    Apparently some water in the fuel filter. Hopefully its that and not some intermittent electrical problem. Thanks everyone, much appreciated.
The topic ‘Semi urgent stuck in Corfu VW T4 van wont start.. Help!!’ is closed to new replies.
