Home Forums Bike Forum Seatpost Stuck… Penetrating Oil?
Viewing 4 posts - 1 through 4 (of 4 total)
  • Seatpost Stuck… Penetrating Oil?
  • Shibboleth
    The EA90 post is seized on my Blur, and whilst I don't move it often, the pollished allow crown is coming unbonded from the shaft, so I can't lever it loose with the saddle or clamp the crown up in a vice.
    What's the best method? Upside down and penetrating oil in through the BB?
    Ta!
    wwaswas
    If you're resigned to losign the post then I'd try a pair of Mole Grips around the shaft and use those to try and rotate it.
    also, you might be better to take the seatclamp out the way and make a 'cup' of plasticine around the top of the post and the split and put the penetrating oil in there – it'll get into the gap far more than just randomly squirting it in from the other end.
    hainey
    Drill a hole through the post, but a bar through and use as leverage.
    thisisnotaspoon
    Mines stuck in my DMR, thats my excuse for being jey and I'm sticking to it!
The topic ‘Seatpost Stuck… Penetrating Oil?’ is closed to new replies.
