Bending it? Nope I assume you drifted the axle out of the main pivot before removing the chainstays though. It did pinch the bearing covers a little though at the main pivot and I remember having to make sure I was properly aligned and ease it on. Same with my repainted genius actually from a little too much paint build up.
The only tricky thing about disassembly/reassembly on the current bikes is having a 3rd hand to keep the bearing inner race spacers in the right place without them falling off and bouncing into oblivion. Even when sticking them to the bearings with grease, I still end up using some method of “chingrip” to keep something in the right place.
