Home Forums Bike Forum Schrader to presta?
Viewing 18 posts - 1 through 18 (of 18 total)
  • Schrader to presta?
  • jonnytheleyther
    Got a compressor for my car, it’s schrader valved, metal sealed unit. Is there a bodge way of converting it to use on presta valves for going tubeless?
    scaredypants
    yes, loads – get a screw-on adaptor for your presta valve
    like this
    scaredypants
    oh, hang on – do you mean an electric car tyre “pump” ? May well not shift enough air for tubeless seating
    mtbfix
    Yep. Thread ends.
    Edit – that was to HS first point but the second point s also valid. Ho hum.
    jonnytheleyther
    Got one of those adaptors but it doesn’t work?
    benpinnick
    Is it a proper compressor or an electric pump type? Does it have a nice big cylinder?
    kimbers
    Just another example of how crap it is we’ve been lumbered with shitty presta for tubeless
    onandon
    So please explain how you’d get better flow with a Schrader valve ?
    Remove the core from a presta and you have no restriction.
    ndthornton
    Just drill a slightly bigger hole in the rim and fit a Schrader tubeless valve (plenty available). The difference in hole size is tiny but you get a significantly larger orifice to force air through into your Tyre.
    PeterPoddy
    Bigger valve, bigger hole.
    But then I’ve never had problem with Presta for tubeless, just remove the valve core.
    onandon
    If you removed the core from a scrader then I’d agree but you can’t from most scrader inner tubes.
    Or at least the ones I’ve seen.
    Then again, I’ve never had a problem with presta with the valve cores intact.
    ndthornton
    Schrader tubeless valves have removable cores
    scaredypants
    I can’t remember ever having a schrader valve (tube or tubeless) with a fixed core
    Tiger6791
    Every Presta tube / valve comes with an adapter in the packet..
    Just use the Presta cap 😉
    Northwind
    If it’s a car tyre inflator, it’s not much use for tubeless anyway, they don’t push enough air.
    on and on – Member
    Sure you can. They unthread internally but you need a wee pokey tool.
    Tiger6791
    wwaswas
    all a bit academic for the OP if it’s just one of those 12v ‘pump your tyres up if you leave it for 20 minutes’ jobs – you tend to need a reservoir of air to get tubeless to seat, not continuous low rate flow.
    ndthornton
    Yeah – what you really need is a lemonade bottle!!!
The topic ‘Schrader to presta?’ is closed to new replies.
