Home Forums Bike Forum Salsa Fargo 27.5 tyre width faff
Viewing 4 posts - 1 through 4 (of 4 total)
  • Salsa Fargo 27.5 tyre width faff
  • WillC9999
    Hi,
    I’ve just bought a Fargo frame with a view to creating a sort of road, towpath, gravel track tourer. I want to run 27.5 wheels (because I have some). I’ve now realised the frame is designed around 29”/27.5”+ and the min recommended tyres with 27.5 (non +) are 3.0”. Mine are currently 2.1.
    Shoving these on the Fargo will drop the BB height a bit. Or maybe a lot, I’m struggling to work it out. Is this going to work or will I just created some kind of human powered lawn edger, i.e. keep hitting the ground?
    And just at this point of mild panic I also realise I’ve been riding the same wheels on a Sonder Frontier, also setup for 27.5+/29, without constantly kicking the ground. Would the Fargo be similarly ok, or is it a disaster waiting to happen?
    I’ve spent an hour googling but I’m none the wiser and frankly my head hurts.
    Thanks in advance 🙂
    WillC9999
    Sorry, ignore this one – I think Trump has messed up the internet.
    ton
    Yes, you can run 650b wheels on a Salsa Fargo:
    Wheel size
    Salsa bikes are designed to work with both 650b and 700c wheels. 650b wheels have a smaller diameter (584 mm) than 700c wheels (622 mm).
    Brake considerations
    jameso
    The Fargo has 70mm BB drop so it’ll be fine with 650B wheels. You’ll get a BB height a bit higher than an average road bike, CX bike sort of position. Ideal perhaps.
