Home Forums Bike Forum Reverb – movement at the top?
Viewing 2 posts - 1 through 2 (of 2 total)
  • Reverb – movement at the top?
  • ltheisinger
    Hi All,
    Just a quick bit of advice if you can….?
    I have had to refit the hose (after breaking the barb off), so I have re-bled the system and checked the air pressure is at 250psi – however, I have a little movement at the top of the travel, i.e. when you sit on the saddle the seat post compresses by about 10mm (ish – maybe a little more?).
    I have re-bled and it is still the same, does anyone know what it could be? Any help or advice would be much appreciated.
    Thanks.
    LT.
    ltheisinger
    Can anyone in the evening crowd help?
The topic ‘Reverb – movement at the top?’ is closed to new replies.
