Home Forums Bike Forum Rent a child bike seat? (Edinburgh)
Viewing 40 posts - 1 through 40 (of 41 total)
  • Rent a child bike seat? (Edinburgh)
  • Gordy
    Having realised that dragging a trailer to the shop then the nursery then work then home then the shop then the nursery then home is a pain in the sac, is there anywhere to rent/try child seats in Edinburgh.
    I'm leaning towards the Co-pilot Limo but also wondering if a rack-mounted seat will be too bumpy for mini-me over cobbles and on canal paths and the like. Would like to try it and see.
    I can't imagine a shop would want it back after I've fitted it all and knocked around with it for a while. Does anyone know of a place that would rent them out?
    If not then I suppose it's the old try it then eBay it approach.
    cynic-al
    Like you, I'd be surprised.
    Must be a lot of them about SH?
    Gordy
    Just checked. There was one on Gumtree in November. Plenty new from eBay shops that are, oddly, more expensive than the ones from proper shops. :O?
    laraichean
    We've got a couple of child seats we need to sell, a co-pilot and a Hamax. Very much good as new, and in Edinburgh, if interested. Email me for more info…
    Gordy
    *scours laraichean's posting history to determine trustworthiness*
    ;O)
    Gordy
    PS – you've got a broken link off the "inside" photo on houseinglencoe.com
    druidh
    Gordy – pop into tbc. We might be able to sort something out……
    leffeboy
    Can you not just lock the trailer up at the nursery? That's what I used to do. Otherwise Topeak have a rack mounted seat that is sprung but it has to be their rack
    Gordy
    Leffeboy – I suppose I could but I'd rather not.
    Cheers, druidh. I'll bear that in mind if I don't just buy both off laraichean. I'll have to swing by for some mudguards anyway. I stupidly forgot to take the mudguards off the old bike I donated to The Bike Station. D'oh!
    Gordy
    Picked them up tonight and they look grand.
    Kindly consider Laraichean a first-rate purveyor of second-hand goods. A+++++ seller, etc.
    igm
    How old are they? A Weeride (if young) or a LOCT if a little older might be a decent option as they get the benefit of the same suspension you do (if it's Edinburgh cobbles I assume your on a full on DH bike – worst road surface in Europe). On the LOCT they can stand up too.
    EDIT: Must read last post.
    Gordy
    Oh, deary me, no no no. Thanks for the suggestion but I can't warm to the front-mounted seat idea at all.
    igm
    Try one – someone will have one you can borrow. Having used both a LOCT and a CoPilot Limo, the LOCT makes for a bike with far more stable handling. And think of it as mid mounted.
    That said a dropper style seat post helps (£60 cheapy one in my case), as do wide bars and grips.
    druidh
    Warning: Small children should never be used in place of an air bag.
    igm
    You have an airbag on your bike?!?
    To be honest though, I've never felt in danger of squashing my son when riding (the endo comment on a previous thread was made up)
    djglover
    There may be a local charity or group offering them. Ealing branch of the London Cycling Campaign have given me a Croozer twin trailer on free loan indefinitely!
    cows_in_cars
    You could try Biketrax next to the cameo, they might be your best bet.
    Gordy
    Thanks for the suggestions but I've already bought them off laraichean.
    Gordy
    Gaaah!
    The rack that he supplied doesn't fit the seat. No problem – bought a Blackburn EX-1. But one of the screws rubs the cassette. Need a spacer of some description. Worse still, the kiddy seat can't go on properly anyway because it hits the rear brake cable. Need to move the rack back a bit but it won't fit the frame on the back holes – another spacer or something needed for that.
    And I stripped at least two of the ruddy bolt heads, probably by overtightening, so I'll need new ones even after I find spacers of some sort that will do the job.
    Where in the name of &*$% can I get new nuts and bolts for a Blackburn EX-1? Anybody know?
    druidh
    Nuts and bolts? Pop in and see us. We usually replace the cheese ones supplied with racks and mudguards with proper ones anyway.
    huggis
    Hi have a coplit limo which has had some use but still vgc. Stay in abdn, £40 if you fancy it. Cheers
    Gordy
    That was fast.
    Your shop, while very good, is inconveniently located for frequent visits. Will try to get in tomorrow. If that fails, can I pay you over the phone and get someone to bung the bits in the post?
    Edit: No thanks, huggis. I'm not starting a collection.
    druidh
    No phone payment I'm afraid. Email me an address and we'll sort something out
    Gordy
    Will do if I don't get over tomorrow. Thanks again.
    Gordy
    I keep getting Mark when I pop in, Druidh. You must be slaving away through the back. Anyway, he kindly continued the Bolts for Biscuits scheme and I now have a nicely secured rack on the Dadbike.
    I think I've hit a terminal bike/seat compatibility problem though, unless I start chopping bits off either the bike or the seat. :O/
    That said, I'll try tilting it back a bit to get more room. I don't suppose the kid'll mind reclining a bit more.
    ojom
    Aye that dunny look right.
    Bring the bike in and we will take a gander at it. Too far forward for sure.
    Mark
    druidh
    You can get longer length fitting kits for Blackburn racks – we should have some in.
    Gordy
    The bike's got a shortened rear triangle, lads. Hang on – I'll find a pikter.
    ojom
    This is a dale isn't it? With the funny dropouts…?
    Gordy
    Aye, here's a photo from another thread. I suppose it's an odd-shaped bike.
    The rack's as far back as I can get it.
    ojom
    Bingo. Thought so.
    Right well we need to look at mounting to the drop outs I expect. Are there some there? Think you mentioned yes earlier.
    If not tapped then we should tap em and see what happens then. We can fit the rack legs done there and that should get us the length we need.
    Make sense?
    druidh
    I can see your groin.
    *stiffens*
    ojom
    Perv
    druidh
    Calling me a perv? At least I don't take photos of my bike in an elevator!
    ojom
    The word you is looking for is Lift.
    Gordy
    I've foolishly shown you mine but please don't reciprocate. ;O)
    Talk of untapped things gettin tapped means nothing to me, sorry. There's a wee hole right at the back of the stay and that's where I've attached the rack. If you have magic ways of moving it even further then I'm all ears and, indeed, biscuits and money.
    Gordy
    I regularly leave the bike lock in the shed so the bike has to come and spend the day in the office on the 8th floor. Keep it quiet. a) I shouldnae be using that lift and b) somebody tripped over the bike and died but H&S don't know!
    ojom
    It means making new holes with threads or making threads in new holes for they wee bolts I gave you today. The legs need to go further back the bike basically.
    Gordy
    Thought that might be what you meant.
    I think we'd actually need more bike in order to move it back, if you see what I mean. I'll have another look at it in daylight and drag the bike in to the shop if it looks like it might be a goer though.
    It's too late for you to be working btw. Away and open a bottle of beer and put your feet up.
    Gordy
    Hmmm – right then. It's the end of the line unless someone has a bright idea because there's no more frame left to move the rack back.
The topic ‘Rent a child bike seat? (Edinburgh)’ is closed to new replies.
