Home Forums Chat Forum Removing thin film off door
Viewing 4 posts - 1 through 4 (of 4 total)
  • Removing thin film off door
  • russ295
    I’ve a recently fitted aluminium front door that has a thin plastic film on and is proving to be a bit difficult to remove.
    It’s coming off in 5p sized bits at best.
    Any tips?
    craigxxl
    Hair dryer to soften up and should just peel off.
    russ295
    Tried that but still won’t shift?
    craigxxl
    Heat it up until you can lift a corner then put the air direction under the bit you’ve lifted and gently pull.
The topic ‘Removing thin film off door’ is closed to new replies.
