Trick with Stans/Tesa/Roval and similiar is tension, and lots of it. You need to be really stretching it out along the length of the tape as it goes on, which is awkward as you’re pulling at 90 degrees to the radius of the wheel and it wants to turn. Grip with feet and knees, pull with arm, is the best way ime, work in fairly short stretches (easier if you have about 12 inches of tape “pulled”, but only stick about 6, then pull another 6 off the role, the extra bit that’s loose helps with the stretching on/tensioning)
If you get enough tension on it like this then it’ll naturally pull into the recess as that’s the shortest route around the wheel. It’s not very stretchy so if you don’t get it on like this it’s really hard to make it conform to the wheel.
That said, I’ve pretty much stopped using it, it’s fine I guess especially with a narrower rim or a pinned unsealed rim where you can’t do the partial taping.
BadlyWiredDog
In true, contrary STW spirit, could I just unhelpfully suggest Mavic UST rims that don’t need tape at all?
Aye, if you want to substitute tape with “far harder to build wheels and weighs way more, enough that Mavic lie about the weights for the entire range, so you end up with a narrower or weaker wheel for the same weight” then they’re great.
