As above, plain BB30A has the bearings pressed directly into the frame. There’s usually a circlip just inside each bearing to locate them/set them in the correct location in the shell.
I just use a screwdriver and hammer to hit them out – be careful to hit the bearing and not the circlip. I use a press at work to put the new bearings in, but you can use a vice if you have one which opens up big enough.
If it really does look like it’s got an adaptor/cups in the frame it’s possible you have an aftermarket adaptor to allow other (e.g Shimano) cranks to be used. e.g. this one
Wheels Manufacturing BB30A to Outboard Btm. Bracket for 24mm (Shimano) Cranks – Black
What sort of cranks are on? Are you able to share any pics?
Alternatively, it might also be PF30A (Don’t you love Cannondale and their standards), which does have cups in the frame.
More info here:-
https://wheelsmfg.com/bb30a-tech-info
