Home Forums Bike Forum Recommend: 120mm 29er Forks
  • This topic has 20 replies, 12 voices, and was last updated 9 years ago by will.
Viewing 21 posts - 1 through 21 (of 21 total)
  • Recommend: 120mm 29er Forks
  • will
    My SIDs are pretty much dead, and whilst 100mm is fine, i’d like the ability to run 120mm for some slightly rougher stuff such as Wales/Peaks etc… and then swap down to 100mm for racing. 20mm thru axel too please.
    Any advise? I’m abit out the game in terms of new sus tech… Where did U-Turn go, that was great!
    z1ppy
    U-turn was replaced by dual position, and I’d agree U-turn was great, as I thought the dual position options too far apart. I always found that you only need to drop the travel by 5-10mm to give you a more XC ride and more than that, you feel your pushing the front wheel into the floor.
    Anyways, 20mm axle are few and far between, though you do get some older RS Rev’s still about with it (2nd hand), IIRC they can have there travel changed (internally) and aren’t overly heavy. Otherwise I think your looking at mainly 15mm axled options, any option to change your front wheel to 15mm? Allowing you to choose from the like of the Reba or X-fusion Slide
    chrismac
    Pikes. Order them from Germany for a considerable saving
    z1ppy
    nahh, I’ve got some 120mm pikes and thought about fitting them to my 120mm HT but decided against it due to the extra A-C height lifting the front end up too much (went on my FS and got upped to 130mm).. and the idea of going from light weight SID’s to Pikes, doesn’t seem the best choice for some-one talking about racing.
    mafiafish
    I’ve got some 140mm revs and recently serviced 120mm rebas both with 20mm axles if they’re up your street? No external travel adjust though – you’d have to change the spacers.
    will
    Zippy – Thanks, I see that 15mm seem to be the norm now, not 20mm. My current wheels (Pro II) can be converted to 20mm, so maybe 15mm too?
    Chris – As Zippy says probably too heavy and not light enough.
    Mafia – Interested in the Rebas. Drop me an email (profile)
    drovercycles
    Or, talk to your friendly local Rockshox dealer who will be able to price-match that Germany quote for you and provide all the added value they bring to the party…
    letmetalktomark
    Thinly veiled FS type post
    I have some NIB 120mm 15mm RCTS SIDs that I need to sell. Bought for a project that never took off
    http://singletrackworld.com/forum/topic/bnib-rockshox-sid-rct3-120-29-15mm-230
    Drop me a mail if interested 😉
    andyg1966
    120mm Pikes for me. Not that heavy either. Same weight as the OEM Fox 32’s that came off!
    vondally
    DT swiss from polish eBay shop, I am imprresed so far had fox fit before
    hopeychondriact
    What Vondally said or go balls out and go for Bos Dizzy forks 😉
    Mini version of the Deville.
    z1ppy
    ahh a Hope front wheel, no problem…15mm adapter kit
    will
    z1ppy
    look just the job, if a tad green, no **** me there actually very green
    letmetalktomark
    I could paint mine green and they would still be cheaper …. and SIDS ….. and RCT3 😛
    will
    Too Green? Bike is black and blue.
    They’re £198 though…
    windydave13
    For the record they are even more green in real life (If thats possible).
    I got the ones from bikediscount for my Kielder101 build. More than impressed with them so far. Did the 4 passes route from Buttermere at the weekend and they were more than capaable and very little noticable flex
    20150815_145210 by Dave Aspinall[/url], on Flickr
    letmetalktomark
    £202 with delivery ….. and they are green 😉 Black and blue bike with black SIDS hmmmm 😆
    I must concede that my Rebas in the same spec as the link above are a very capable fork.
    thepodge
    I have some Rebas if they are any use to you
    Rock Shox Reba RTL 29”
    Taper Steerer
    180mm Steerer Length
    15mm Maxle Included
    Set at 120mm
    Excellent condition
    £155 Posted
    Might be able to do mates rates
    leegee
    Manitou Marvel Pro is great.
    will
    Podge. I’ll drop you a message! I think the steerer may be 5mm-10mm too short, but let me double check.
    WindyDave – They really are green!
The topic ‘Recommend: 120mm 29er Forks’ is closed to new replies.
