I’ve not long had some Reba Team Air U-Turns – the 80-115mm travel ones with poploc and all that.
Anyway, got the bike out of the shed yesterday and I noticed that there is more stanchion showing than travel indicators – so there is probably a 5mm gap between the seal and the 115mm indicator with the adjuster wound fully out – more like 120mm travel, then I guess?
I let all the pos & neg air out and reset so they were the same pressure (145psi). This gap was still present, even after cycling the fork a few times – they seem to work fine, but I’m not sure whether this is OK or not. Should I wind the adjuster down to the 115mm mark, or just forget aobut it?
