Home Forums Bike Forum Reba air spring service – grease or oil
Viewing 8 posts - 1 through 8 (of 8 total)
  • Reba air spring service – grease or oil
  • empy
    From 2010 SRAM seem to be recommending grease rather than oil – whats best for a 2009 SL fork (on its last legs and leaking air between chambers). If grease, what grease?
    Also about to adjust travel on my new Revs RLT and there will be grease in there – should I swap with oil?
    lotus777
    grease for the air spring.
    get some from tf tuned or mojo
    nuke
    I’ve noticed grease in forks when I’ve serviced them but the the service manuals are never too specific on what to replace with. I’ve used Rock N Roll Super Slick on seals which seems to work well. I’m also tempted to use some Manitou M-Prep which I bought for my Turner frame’s bushings….seems a good consistency
    empy
    Thanks. I’ve got some Pitstop Judy Butter – that OK? Seems very light to me but maybe that’s what’s required.
    lotus777
    sorry, ignore my post above, just found this ;
    http://www.sram.com/_media/pdf/rockshox/dealers/TM_MY09_E.pdf
    empy
    OK – this seems like a general issue – what’s best at keeping the air spring O-rings lubed and leak free – grease or oil. Have Rockshox moved to grease recommendation for a particular reason. I’m confused. Does it really matter?
    andyl
    you want something silicone based for the forks as it won’t mix with the oil and will preserve the o-rings.
    I use Stendec stuff but I think the RnR Super Slick and Manitou M-prep is also very similar and silicone based.
    lotus777
    sounds like oil would be best as ,from what i read in the above manual, it seems there are foam rings in the air spring which would absorb the oil helping lubrication .
The topic ‘Reba air spring service – grease or oil’ is closed to new replies.
