Home Forums Bike Forum rear mech issues
Viewing 24 posts - 41 through 64 (of 64 total)
  • rear mech issues
  • sadexpunk
    well as my mate had suspected, it looks like a wheel/axle width issue.
    he’s lent me one of his wheels with a 9sp cassette and theres no issue. put mine back on and it skips again. the difference in widths is minimal but ‘just enough’ to cause an issue.
    these 2 pics are my wheel…..
    these 2 are my mates wheel…..
    you can see the chain is close to the stays on mine which is causing it to ride up on the cassette, trying to get onto the next cog up. mech is at its max, same with the other mech i tried.
    i guess theres nothing i can do to ‘widen’ the axle a mm or so, or at least the bit from cog to the part the dropout sits on?
    so will this frame only work properly with a different wheel?
    thanks
    lucky13
    were any of these removed from your wheel?
    – cassette
    – freehub
    – axle end caps/spacers
    – axle
    it’s possible that one of them isn’t fitted right and that has moved the position of the cassette out slightly
    sadexpunk
    the bike is new to me, ive never ridden it yet. once acquired i stripped it, had it resprayed and went 1x.
    the only thing ive changed on the wheel is the cassette because this was happening on the old cassette too.
    i dont know my way around wheel innards, can i take it to bits and insert a spacer or anything?
    Jordan
    Looks like QR? Is it cup and cone bearings? You might have the axle protruding more on the non drive side than it should be.
    sillyoldman
    Axle protruding more on NDS wouldn’t make any difference. Looks like you need a small washer between the DS cone and locknut to increase the distance between 11T sprocket and dropout.
    sadexpunk
    thats definitely the distance that needs widening, is it possible? ive got absolutely no idea how these things come apart (or more importantly go back together) 😀
    sillyoldman
    What model is the hub?
    sadexpunk
    American Classic
    Jordan
    Actually @sillyoldman is correct now that I think about it and his solution should work.
    Edit: You could test for this by seeing if your mates wheels are a tighter fit between the drop outs, with the QR loose of course.
    sadexpunk
    i think even if it wasnt, theres plenty of spring in the frame to be able to take 1mm-ish of washer.
    question is, how does it all come apart for me to do this and what size/sort of washer would i need? any youtube vids?
    thanks
    Jordan
    Just looked at that hub and seems it’s sealed bearings so above advice doesn’t apply. When you replaced the cassette did you notice if there was a spacer behind it?
    sadexpunk
    there isnt no, i took it off and checked it again today…..
    Jordan
    You have tried loosening the high limit screw and adjusting the indexing haven’t you?
    sadexpunk
    screw is screwed out waaaay past its top limit, and the cable isnt connected to the mech. so the mech is as far over as its possible to be. its a purely ‘untensioned’ mech.
    Jordan
    Beats me then, theres normally enough range with the H limit screw to pull the chain off into the frame.
    lucky13
    so the problem might have already been there there when you first got the bike?
    that could mean previous work on it left it that way.
    assume the cassettes are fitting securely with no play – so they can probably be ruled out.
    Jordan
    Have you tried physicaly pulling the rear mech across to see if the chain will stay on the cog. Could be a chain tension/line issue with the 1x convertion. Is the chain long enough?
    sadexpunk
    possible, and that as it was 3x then that smallest cog may never have been needed so problem not identified.
    yes, happened on original worn cassette, and also happens on this second one which has been off and on a few times for double checks.
    yes i think i have, cant remember now if that proved anything one way or another so should maybe try that again now i know the problem is the wheel.
    new chain set to the original chains length which goes round the mech and largest cog easy enough. the 1x conversion is just using original crankset and taking 3 rings off and replacing middle one with an oval ring. which is in the same place as the original middle ring so should be bob on.
    the telling thing for me is that it works with a different wheel but not this one, and that there is a difference in spacing between the wheels. mine is almost touching the chainstays and looks like its too close.
    thanks
    Jordan
    Looking at the manual,link here there does seem to be a couple of spacers on the drive side which may have been assembled wrongly in the past. Might be worth stripping it down to have a look.
    lucky13
    good spot. impressive that American Classic still keep their manuals online even thought they shut down three years ago: http://www.amclassicsales.com/amclassic.com/en/help/manuals
    make sure it is the right hub though: http://www.amclassicsales.com/amclassic.com/download/manuals/identifying_rear_mtb_hub.pdf
    the rim looks like a Stans ZTR, so i’d guess that it is a Stans wheelset with OEM hubs from American Classic? so some details like model number and freehub colour may not match.
    if the hubs are a version of the Terrain hub it is possible that the end caps have been mixed up. they are 11.0mm on one end and 9.2mm on the other and the side they go on varies with the freehub. having them the other way round would move the hub across by 1.8mm.
    this is the manual for the Terrain: http://www.amclassicsales.com/amclassic.com/download/manuals/terrain_overhaul.pdf
    another sign to look for first is if the rim is closer to the right seatstay than the left side. (assuming it is true). flipping the wheel can help compare as that will reverse the gap. if you try that then shift to the small sprocket to keep the mech and chain away from the disc.
    sadexpunk
    cheers chaps, very helpful.
    ive measured the distance from rim to frame, reversed and re-measured. all seems central and as it should be.
    as per the manual link, ive identified the serial number which begins with an A, so from what all i can tell that just means its a 9/10 body not a 10/11 body.
    the pic to me looks like the very first top hub in your first link, would you agree?
    thanks
    Jordan
    Yes, it looks like the 225 hub which is the manual I linked to. The one with the drive side spacers. Easy enough to pull the axle out and have a look, if someone has put both spacers inboard of the freehub then that would shift the cassette across towards the frame or if they have left them out altogether it would have the same effect. You could even try adding an extra spacer/washer on the axle at the drive side end to try and shift it as long as it leaves you enough threads for the nuts at the other end. Comparing your photo with the one in the manual, you do seem to have a bit more axle showing on the NDS than the one in the manual. Those spacers could account for that.
    lucky13
    yes – could be missing that spacer between the dust seal and the freehub
    here’s a good photo of the NDS should look: https://clee-cycles.co.uk/56550b73e4b0c763614835ec.jpg
    sadexpunk
    well, time for an update, and happily its a good update! id been ready to give in, accepting that i wont get to ride it this summer, bloody bike, just cant get it to shift properly, am i going to have to buy a whole new cassette/mech/shifter/chain? why oh why oh why??
    my mate came round to have a look, and he was baffled too. changed mechs, changed spacers between cassette rings, kept checking alignment with his home-made tool, it all just left us scratching our heads. solve one issue and it was shit elsewhere.
    then he just asked if id changed the cassette lockring. no idea, why would that matter anyway? he said that he’d heard of it before, and that lockrings can be the wrong sort, so i went looking through my box of trinkets. sure enough another lockring. the one on the bike was a 105 lockring, the one in my box had a number that started with M and was a little more domed rather than flat, so we guessed it may be more suitable and just changed it in hope really.
    aaaaaand bingo! i owe him a pint or two for that, id never have thought of it! 😀
    anyways, for those of you that can remember this from a few months ago i thought you may be interested in what the solution was.
    thanks
The topic ‘rear mech issues’ is closed to new replies.
