Rear cassette 'slip...
[Closed] Rear cassette 'slipping'...?
Now and again (im pretty certain...) the cassette almost slips, or moves a little, usually when pedalling quite hard. Obviously i have never seen it happen, but you get the feeling through the pedals and a loud crack when it does.
Is this the freehub body wearing out? Or freewheel mechanism? Im just worried one day it will slip completely with a painful result... ๐Ÿ˜ฏ
Hub is XT, a few years old now but bearings are ok.
Advice appreciated.
Posted : 15/04/2009 4:58 pm
I always thought that sound was the pawls going? So yes, freehub/freewheel could be on it's way out?
Posted : 15/04/2009 5:04 pm
Could either the a knackered freehub or the chain slipping perhaps??
Posted : 15/04/2009 5:08 pm
Its definitely not the chain...
Posted : 15/04/2009 5:10 pm
 J0N
I had this problem. XT freehub was full of crap and was making the pawls miss the teeth. The clicking sound had been almost silent for months so that could be a tell tale sign. Clicking is back to near normal but I've not had it back as I've been using another wheel so I'm unsure if the problem is solved.
Posted : 15/04/2009 5:13 pm
It's not uncommon for shimano freehubs IME, and doesn't bother me. I think it means a pawl is not 100% engaged and slips.
Posted : 15/04/2009 5:18 pm
Forgive my ignorance, but what do the 'pawls' do? Are they serviceable, or a part of the freehub unit?
Posted : 15/04/2009 5:25 pm
From Sheldon Brown: Pawl
A spring-loaded part that engages a set of teeth when moving in one direction, but slides over them when moving in the other direction. The pawls in a freewheel make a ticking sound when a bicycle coasts. Most freewheels have two or three pawls.
Best explained by looking at a Hope service diagram as they use external (to the freehub) pawls.
The shimano ones can be serviced but are not really designed to be - you get a spare freehub as a closed unit and bolt it back onto the hub. Hope ones can be dissembled and spares got for it.
If you do go the route of a new freehub, check the part number and you may find that it's cheaper to get the freehub as part of a full cheap hub as opposed to a single part, and you then get a spare set of cones, bearings, axle, etc. as part of it.
Posted : 15/04/2009 5:34 pm
FWIW I've had this on several hub which have lasted for ages afterwards
Posted : 15/04/2009 5:35 pm
Excellent, thanks for the help lads ๐Ÿ™‚
Posted : 15/04/2009 5:40 pm
I have had it on 3 freehubs all of which failed dramatically shortly afterwards - on the tandem tho which does put more force thru them. I would replace asap. One nasty fall, one long walk home and one ruined ride was the results
Posted : 15/04/2009 6:21 pm
