Home Forums Chat Forum Rate my Brickie….
Viewing 40 posts - 601 through 640 (of 749 total)
  • Rate my Brickie….
  • wwaswas
    and again
    [edit] we end up with more glitch bumps than posts after the first 10 pages.
    weeksy
    This is all insanity taken to the next level…. i’m truely truely bemused by it all.
    footflaps
    Just wait till I add the swimming pool for the sharks with lazer beams on their heads…
    Nick
    Should have built a spiral cellar into the floor
    pleaderwilliams
    Isn’t that beam going to be a massive cold bridge?
    footflaps
    Probably – will get boxed in at some point.
    EDIT: Won’t be that massive as the edge surface area is tiny.
    Murray
    <slight highjack>What do you do about cables/sockets if you use Celotex boards? Presumably they’re a potential air leak and heat bridge. I know there must be a good answer but at 04:00 in bed this morning I couldn’t think of it.</slight highjack>
    wwaswas
    surface mount them in boxes?
    footflaps
    As it’s a workshop, I’m going to surface mount all the electrics as I don’t care if it’s not flush. You can get recessed sockets etc for insulation and it wouldn’t make a significant difference in the overall U value for the whole building, but that would involve knowing where I want all the lights etc before I insulated, and I haven’t thought about that yet….
    Hmm you too? I thought I was the only one lying awake at night thinking about what to do next / how to do it…..
    footflaps
    Geeky info on the insulation fixings – found the data sheet:
    [/url]
    Spit ISO Insulation Anchor[/url] by brf[/url], on Flickr
    footflaps
    Tonight’s activity was fitting the RSD. Total PITA as the instructions were next to useless and the motor roller is too wide for the opening, so either one of the guides is bent, or the shutter can pop out.
    [/url]
    ’Auto-Roll’ Roller Shutter Door Installed[/url] by brf[/url], on Flickr
    weeksy
    Are you running a business out of the workshop or just for day to day stuff ?
    wwaswas
    It’s literally a bike shed.
    davidjones15
    Didn’t it arrive as a plug and play, pre assembled unit?
    Who did the measuring? I’m not sure what the problem with the guides is either.
    footflaps
    I measured the opening and they cut the thing to size and deliver it in parts:
    [/url]
    Roller Shutter Door[/url] by brf[/url], on Flickr
    The problem is, they don’t cut the motor to size, but (I guess) have a range of set length and each motor roller has a bar on one side which slides in and out to allow flexibility for a range of openings.
    However this one is too wide for the opening (ie the adjuster bar doesn’t retract enough) so the right hand flag pole bracket is pushed right out at the top, twisting the frame. The spacing of the vertical tracks is specified at shutter width + 40mm, which is what I’ve installed it at. To fit the motor, it needs to be +60mm, which will reduce the shutter overlap in the guide rails from 20mm to 10mm, which would be quite easy to pry out. I may dismantle the whole thing and cut the expansion bar in the roller.
    As for the electrics – no instructions, 4 wires (coloured) and a PCB with non-colour, non-industry standard labels (NB I am a Chartered Electronic Design Engineer, so do know about these things). I just applied pot luck and guessed ok first time – but pretty shoddy as all they needed was a piece of paper with 4 lines on it…
    I wouldn’t recommend Auto-roll to anyone.
    footflaps
    I went for the RSD for security and also, ‘out of sight, out of mind’. The main door is a glass patio door for light and convenience. The RSD is just to close at night for security.
    These get fitted at the WE:
    [/url]
    Doors….[/url] by brf[/url], on Flickr
    marcus7
    Good God, that is by far BY FAR the most “over the top” bike shed i have ever seen EVER, it must be costing a fortune! well done, I am very impressed!
    davidjones15
    I’m not too clear on the problem, but it sounds like the laths are too short, no?
    That is to say that the minimum width is determined by the motor (and weight of shutter) and not the opening. The guides and laths should fit this and would be oversize for the specified opening.
    Get back on to the supplier with this and tell them that as they are the experts they should have pointed this out. You relied on their expert opinion and they gave bad advice. It shouldn’t require any more than a new set of laths.
    That depends on whether I have understood correctly or not. Photos of the problem would be good.
    It is a bit of a nightmare doing these things on line though.
    footflaps
    Either way I have to take it all down, it which case I may as well cut 20mm off the motor axle expansion bar thing and re-fit it. Quicker and less hassle than them sending me a new motor roller….
    As for taking it all down, putting it all up – the shutter door is a two man lift and has to be held up vertically to be bolted to the motor roller, requiring a third set of hands. Mrs FF and I managed it with a make shift hoist, some blood loss, a lot of swearing and then a lot of chastising over my swearing. Not something I’m looking forward to again….
    bruneep
    Are you accessing the cave via an underground tunnel, or are the doors just laid on the grass?
    davidjones15
    Not good however you look at it.
    footflaps
    I’ve installed ICBMs in the lawn as a deterrent, the doors are just until the proper steel launch doors arrive for the ICBM chambers…
    As for the workshop, this is how it should look after the first fit:
    bruneep
    Should’ve went for the Titan 3 🙄
    kingkongsfinger
    Footflaps, pm me if you need help with the RSD, I have been fitting and selling industrial doors inc. the RSD type you have for over 20 years, I will help you if needed.
    For the record, thats how a RSD is delivered, bundles of 6-8 lath and you put the sections on one by one by bending one of teh nylon endlocks to the side and then slide the other section in.
    The lath is a standard 75mm 22 swg scrolled type, side guides look a bit cheap and flimsey. i cant see the motor to comment on it.
    easy way to install the RSD with no instructions is measure overall the nylon endlocks on the lath and they fix the sideguide angles about 30 mm wider than this measurement. Make sure they are plumb and sqaure. Drop the barrell in the cups on the endplates and then fix that lath in sections as I mentioned starting from the top. Its V important that the first section of lath is fitted square and level on the barrell as the rest of the door curtain with roll up on the p155 and “bag up” and jam. Last thing is to fit the guides to the guide angles and set the motor limits. That size door is 1.5 hr job max.
    kingkongsfinger
    Agreeded about Autoroll in the NE, they “used” to be one of my customers, as i used to supply them parts to manufature and repair doors. No further comments needed.
    footflaps
    easy way to install the RSD …….
    Thanks! I have no sussed it all out, just it would have been nice to have had decent instructions with it….
    The hardest bit was lifting the whole thing up to bolt to the motor, using just the edges of the shutter. How do you do it?
    Tonight I’ll fit an eye bolt into the blocks above it, so I can just take the weight on a rope and haul it up and down rather than trying to hold it in place and bolt it all whilst two people are standing on a step ladder.
    footflaps
    I found a second hand Titan 2 kit on Ebay going cheap. Only fired once – seemed like a bargain to me…..
    davidjones15
    How do you do it?
    You could mount the guides to the end plates to form a big U.
    With two people simply lift into place and screw down.
    kingkongsfinger
    footflaps – Member
    Not 100% sure what you mean. If you have already installed the two side guides, you then need to fit the barrell next. You do this (with a small door like yours)by putting two ladders between the guides resting on the lintol and two people put the barrell in there arms like a baby, walk up the ladders together and then drop the barrell shaft into the cups on the endplates. Make sure their is some type of fixing that stops the barrell shaft coming out of the shaft when operating, this would be a disaster if it came out. We used to sell this type of door upto 7 m square!!! Imagine the size and weight of the barrell 7 metres long to stop the deflection, it was a hard days graft fitting them!!
    kingkongsfinger
    Re. the above fixing info, I am assuming than the endplates are already bolted, welded to the side guide angles (they should be) These are known as flag guides, as they look like falgs when you stand them up to fix them to the structure.
    footflaps
    Installation order was:
    1) Flag poles into wall
    2) Roller motor into flag poles
    That was all quite straightforward. Hard bit was lifting the whole 2.5m roller shutter up to the barrel to bolt in place. Heavy and hard to grip as you need one person each side, on step ladders (we only had one).
    footflaps
    *glitch bump*
    wwaswas
    glitchy bump
    footflaps
    bump x2
    footflaps
    bump x3
    What’s with the whole ‘Slow down you move to fast’ nonsense – you need 3-4 extra posts just to get the next page to work properly……
    flatfish
    Concur with Kingkong.
    I’ve been fitting RSD’s for about 15 years too.
    davidjones15
    Quick vid on mounting guides and box.
    franksinatra
    Good God, this things is a fortress. Do you have even a tiny bit of doubt in your mind that it might be slightly overkill?
    Is there not a risk that a master burglar will try to rob you just for the challenge, bit like in Oceans 11?
    Edit (still love it though, well done!)
    kingkongsfinger
    davidjones15 – Member
    Good video and try. But wrong type of RSD, wrong application for an industrial type roller shutter for the “mega structure!”
    footflaps
    It is a project, rather than a means to an end, plus I already have a wooden shed, so thought I’d try something a bit different….
The topic ‘Rate my Brickie….’ is closed to new replies.
