Just had the first ride with AXS gearing (around Cannock @Kryton57 – watched some of the racers and they looked in pain).
Whilst the shifting is crisp and great, when under pressure and needing to grab either higher or lower gears, I always cocked it up and went the wrong way.
Not sure what is going on but, I instinctively push with my thumb to make it easier and pull with finger over the bars to drop down. The previous XTR 12 sp with X01 rear mech I had working like butter and tempted to go back.
Will have a go moving the AXS lever and look at the button settings to see if I can get it any more intuitive.
I had the same experience first ride on GX AXS and was wondering if I should sell it on and go back to cables.
I tried swapping the buttons around in the app so the top of paddle makes it easier and the bottom makes it harder and things are much better. Still a bit unintuitive but I’m getting used to it I think.
I definitely like the crisp shifts so I’m planning to give it a good 10 or so rides to get properly used to it before deciding whether to give up.
