Home Forums Bike Forum Possibly the stupidest question ever – front wheels
Viewing 22 posts - 1 through 22 (of 22 total)
  • Possibly the stupidest question ever – front wheels
  • RealMan
    Is there a right way to put them on? Looks completely symmetrical except for a decal which is only on one side of the hub. Even looked at the instructions but can’t see anything useful.
    highclimber
    i have ridden with mine on the ‘wrong’ way for a while before noticing, never did me any harm!
    wwaswas
    disk in the caliper always works for me.
    RealMan
    Rim brake, non disc hub..
    nbt
    rim brake wheels can go either way, the tyre might be directional
    uplink
    Goes in any old way it finds itself on my road bike – not died yet
    wwaswas
    I think I knew that 😉
    as above – it’s probably more about
    a) directional tyres
    b) brake blocks being bedded into one side of the rim rather than the other.
    thomthumb
    quick release on the lhs
    RealMan
    Its a new wheel, so no tyre or wear or skewer yet. Will just bang it in whichever way then.
    soobalias
    i really think you will want a tyre on your wheel
    cynic-al
    LOLs @ Wwaswas
    druidh
    Common practice is to build the wheel so that any logo on the hub is readable the right way up when seated on the bike.
    – unless it’s a DT Swiss disk hub 🙄
    njee20
    Rim decals right way up when the bike is viewied from the drive side too.
    Teehee!
    Onzadog
    make sure the rim sticker is readable from the same side as the rear hub. You do have matching rims don’t you?
    Dibbs
    Wheel magnet the same side as the computer sensor.
    TheBrick
    rim graphics should be readable from the RHS if you want to be pedantic.
    amedias
    leftwards
    RealMan
    Just to let everyone know it’s been done. Whether it’s been done right or not is another matter, I may post pictures later so that I may receive your unquestionable judgement.
    mudpup
    Its useful to change the direction every couple of rides so the rim sidewalls wear evenly.
    cynic-al
    I log how many clockwise and counterclockwise loops I do and rotate the tyres accordingly so the cornering part wears symmetrically.
    vinnyeh
    Whichever way spins longest.
    Some bearing sets will spin better in one direction than the other- when I remember I tend to check the wheel both ways, and go with the direction which spins best. There won’t be much in it, but in some circumstances every bit of help counts.
The topic ‘Possibly the stupidest question ever – front wheels’ is closed to new replies.
