Home Forums Chat Forum PC with no sound
Viewing 5 posts - 1 through 5 (of 5 total)
  • PC with no sound
  • paddlemyowncanoe
    My Sony Vaio has lost its sound – I did drop it once. Under control panel there is no sound output device listed. Headphones don’t work either.
    Curiously, when booting up I do get the Intel ditty, and a ‘welcome to new hardware wizard’ window which leads nowhere though.
    Is this fixable?
    kona_uk
    Do the sound drivers need re-installing ?
    Perhaps thats the new hardware it has found ?
    paddlemyowncanoe
    I don’t have the disc and the hardware screen doesn’t show the name of equipment for me to search the web for.
    kona_uk
    There are a few sites that can scan your PC’s hardware to identify what sound spec you have….just do a search..
    Then once you have identified the sound hardware just download and re-install the drivers.
    kona_uk
    Or just remove the side panel on the tower and have a look inside. But be aware of warranty, as it can be voided by removing a panel.
    If you are using Windows, there is the facility to show a list of hardware installed.
The topic ‘PC with no sound’ is closed to new replies.
