Home Forums Bike Forum Other than the On-One +5mm, how do I slacken my head angle?
  • This topic has 6 replies, 6 voices, and was last updated 16 years ago by ton.
Viewing 7 posts - 1 through 7 (of 7 total)
  • Other than the On-One +5mm, how do I slacken my head angle?
  • rolfharris
    I’ve just fitted some new forks and have come from Marzocchi 6″ forks to Magura 5.5″ ones, and all of a sudden I feel over the front and not particularly comfy. Is there a way of re-slackening my head angle, like the +5mm On One headset, but probably a bit taller. I’ve already got 1.5″ of spacers and a high rise bar, so don’t really want more there.
    Steve-Austin
    Fit a bigger front wheel
    takisawa2
    Let your rear tyre down.
    GW
    This is a hardtail you’re on about, aye?
    run a larger front tyre than rear
    run less sag in the fork. (stiffer spring/higher air perssure rather than more pre-load)
    use a taller stack lower headset cup.
    if it’s a full sus, running more rear Sag would lower your BB and slack it out too.
    solamanda
    What dampening adjustments does the fork have? Adjusting the fork so it sits in it’s travel better and dive less will have the desired effect. It could be you’re used to a firmer fork or with better adjusted dampening.
    coolhandluke
    20″ rear wheel?
    ton
    vic, do you see what i meant now.
The topic ‘Other than the On-One +5mm, how do I slacken my head angle?’ is closed to new replies.
