So I want to inspect the graphite core of an aging nuclear reactor with regard to extending it’s lifespan given the current energy crunch. I’ve had a look online and proper PPE seems quite expensive. I was thinking of using bacofoil for underpants?
Can anyone advise if this will work?
Also gloves, are they really necessary – they’ll be quite sweaty and I won’t be able to write clearly on my clipboard etc…
Are you actually being serious? On the assumption that you are I’d expect hard hat, safety specs, coveralls, gloves and steel toe capped boots to be the minimum requirement just to allowed on site with anything extra as required by a risk assessment for that particular task.
We seem to be getting ridiculous scenarios for difficult/dangerous jobs with questions, from what appears to be the village idiot, being asked on how to make these jobs easier/cheaper…
Suspect someone has posted up asking a genuine question about something but others have decided it was daft so now trying to make others up…
Bacofoil underpants are not necessary, however you may fancy to fashion the tinfoil into some type of rudimentary millinery. It stops sunburn so should stop any nasties from a mere power station; after all, the sun is bigger and would win in a fight. Gloves likewise.
Factor 50+ for the rest of you and you’re good to go, etc
You’re obviously serious, so the technical answer is that tin foil will protect you from beta particles and bacon grease. Not so good against gamma particles, unless you buy the super strong stuff from Morrisons.
Some really poor advice here.
The correct answer is to find a gap year student studying nuclear physics and hire them to do the work. Make sure your lawyer gets the contract right so the university remains responsible for settling the lawsuit.
Surely if Covid has taught us anything, it’s that making a face mask out of your old pants and wearing it so it’s tucked under your nose protects you from anything.
Kit already exists, either NICIE or NICIE2 (New In Core Inspection Equipment) all done by cameras and trappanning of samples for external inspection under electron microscope. No lead pant required!
neila
I think the op wants to use sun cream and a hammer. Let’s not kill his dream!
Having worked with James Fisher over the years I’m surprised that they’re even bothering with PPE… My firm is the world lead on reactor graphite inspection and sadly it’s all remote, no tin-foil undies required.
Are you mad? No hi vis. HSE will lock you up and throw away the key.
