Morning all, got some brand new Deore M615 brakes, and put new rotors on at the weekend. I had to push the pistons in a bit, and I did the rear piston while the bike was upside down. Turned the bike over and the lever pulled to the bar.
I’ve fixed it by doing the old ziptie the lever to the grip overnight trick, and they’re fine again; but was wondering if this should have happened with a brand new set of brakes – presumably they should have come fully bled? Seems like there’s definitely air in the system.
Is there a quick fix? Doesn’t seem worth a full bleed when the oil will be brand new and sparkling clean – any way I can just top it up, or am I just being lazy?
Thanks.
