Home Forums Bike Forum Mixing a Deore shifter with a Saint derailleur?
Viewing 6 posts - 1 through 6 (of 6 total)
  • Mixing a Deore shifter with a Saint derailleur?
  • flowerman
    Is this Ok? Will It work, surely if they are both the same manufacturer it will work?
    Thanks
    julianwilson
    Yes, so long as they are both either 10 or 8/9 speed. You can’t mix 10 and 9 speed mountian bike stuff even if it is all shimano as the cable pull ratio is different.
    flowerman
    No sorry they are both 9 speed. Cheers!
    julianwilson
    Then it will be fine. Happy spannering. 😀
    professorfaceplant
    yep mixed XTR mechs and Deore shifters, eventually i’ll get round to some better shifters, but the combo works fine, so can’t justify the expense
    zerocool
    Yeah, it’s all good. Brian Lopes runs SLX/Deore shifters with XTR and Saint as he prefers that they single shift with each lever throw.
The topic ‘Mixing a Deore shifter with a Saint derailleur?’ is closed to new replies.
