Home Forums Bike Forum Losing parts too small to see.
Viewing 13 posts - 1 through 13 (of 13 total)
  • Losing parts too small to see.
  • mcmoonter
    I went for a spin on my Vaya this morning. Something picked up into the brake caliper, when I removed it one of the domed caliper adjusting washers pinged off into the leaves.
    I was like Thema from Scooby Doo searching for something without her glasses. I ended up giving up, wrapping the caliper around the bars and riding home with just a back brake.
    Anyone else needing a visit to Specsavers?
    Does anyone have a spare rattling around in their spares box?
    All was not lost, I still had time to get out for a spin on the El Mariachi – liking it a lot!
    Olly
    i have a silly strong magnet i pulled out of an old hard drive (one of those rare earth jobbies i think)
    has saved me quite a few times in the shed and on the patio.
    Bit excessive to take it on a ride though
    LoCo
    Magnets, telescopic one so you don’t have to bend over & rubber mats with holes in to catch stuff makes life a lot easier
    The tiny ball bearings out of fox forks lockout levers are particularly bad for jumping out your hands 😉
    oliverracing
    I was riding at night last year when the only light I had decided to spring off into the bushes and fall apart – I found all the parts bar the bulb after about 30mins searching, so rode home in the dark. I now always ride with 2 lights at night
    z1ppy
    I dunno I stripped my Hope hub friday, put the springs & pawls in a tub of degreaser… 4 of each went in, 4 pawls & only 3 springs came out. Where the **** did the other one go?
    (luckily I’d ordered some spares)
    Stevelol
    There still an adaptor for my stans sealant injector in the hedge at my parents’ house, that was a boring 45 mins of searching. Turns out you don’t really need one anyway!!
    unovolo
    I’d check that 2 of the springs have not become intertwined with one and other, especially if they are quite small & fine.
    Seen it before and upon first glance it just looks like 1 spring.
    muzzle
    If you mean one of those washers that you also get on v-brakes to adjust the pad angle, I think I’ve got one or two knocking around.
    cynic-al
    Pete they are just std v brake spacers – any lbs should have some in the bin.
    Often aluminium though, so no help from a magnet!
    z1ppy
    Unvolo, it’s back together now, I’d imagine I’d have noticed two ‘together’ when fitting… but maybe not, going by my track record.
    br
    Half-way down a decent descent in a forest on Friday and one of the rear pads delaminated (yes, I was mincing down).
    Anyway as I’d twatted my X2 caliper last week and had replaced it with an older Hope off my sons bike I just got out the spare pads and found it had a sprung pad bolt with retaining wire. Took it out and then could I get it back into the worlds smallest hole? Nope, couldn’t even see the bloody hole!
    Finally lost it and ended up with a single strand of gear wire held by a tie-wrap.
    mcmoonter
    Cheers Al.
    metal_leg
    Doesn’t matter where you lost it. It’s under the fridge.
The topic ‘Losing parts too small to see.’ is closed to new replies.
