Home Forums Bike Forum Longest seatpost shim?
Viewing 6 posts - 1 through 6 (of 6 total)
  • Longest seatpost shim?
  • Simon
    I need a 27.2mm to 30.9mm shim so I can use a 27.2 mm Gravity Dropper in a Spesh frame.
    I want the shim to be as long as possible, who makes the longest?
    Simon
    Saturday morning bump.
    njee20
    USE are a good length, dunno if they’re the longest.
    Yetiman
    My USE shim is a fairly decent length. I’m not sure how it stacks up to other shims though, as I’ve only ever used USE ones.
    freeride_frankie
    The gravity dropper one is 100mm long.
    johnners
    My USE plastic 27.2-30.9 is 90mm (inserted bit). If you need more you could always cut the top off another and use both on the post. Would maybe mean fishing out the lower one with an old spoke when you remove the post but do-able.
The topic ‘Longest seatpost shim?’ is closed to new replies.
