Home Forums Chat Forum Like Crocs, but with grippier soles?
Viewing 34 posts - 1 through 34 (of 34 total)
  • Like Crocs, but with grippier soles?
  • blokeuptheroad
    Don’t judge me. We live in a semi small holding out in the cuds. I live in Crocs or wellies when I’m at home. We have no near neighbours, so there’s no one to see my dignity and self respect seeping out through the little holes in them!
    Crocs are really practical, when you’ve quickly got to nip outside for something, without the faff of constantly taking wellies on and off. The only downside is on certain surfaces, anything wet or muddy, they are lethal. I’ve gone on my arse more than once. Even my garage floor which is epoxy paint, is like an ice rink in wet Crocs.
    So what is there that is as comfortable and effortless to slip on and off as Crocs, but with a safe, grippy, non-slip sole?
    hot_fiat
    Are you a dentist or a mortician? If not, not crocs.
    Hunter and Aigle do a short wellie. Do you have a boot jack? Avoid the plastic or wooden ones and seek out a decent cast iron one. Makes dealing with wellies so much easier.
    1
    fazzini
    ATCs
    I give you the All terrain Crocs…I believe you can also get them in a lined version for colder times 🙂
    blokeuptheroad
    Yes we have a boot jack and Aigle wellies which get a lot of use. But when you are in out, in out all day long, constantly taking wellies on and off (even short ones) becomes a right PITA. So whilst the wellies will still get plenty of use, there is a need for something I can slip on and off, without using a boot jack or without having to bend over or sit down to take them on or off. I.e. Like Crocs but with grippy soles 🙂
    2
    db
    I live in All terrain Crocs. I started the whole trend of socks and crocs – I was wearing this before all the cool kids were.
    (Still slippy on painted garage floor!)
    1
    blokeuptheroad
    @fazzini thanks! They might fill the bill. Slightly suspicious though that whilst they have a more aggressive tread pattern, it looks like it’s moulded from the same plasticy material which is inherently slippy when it’s wet? Have you tried them?
    Edit: @db thanks for the first hand experience!
    1
    nbt
    Dunlop welly shoes is the forst thing that cam up when I searched for “Garden shoes”
    https://www.shoezone.com/Products/Dunlop-Unisex-Black-Garden-Welly-Shoe-814P-79403?siz=10&msclkid=24723dfa3fbd181a918458eca388c1d1
    I got something similar from Aldi / Lidly for Mrs NBT, should have got a pair for myself – these have a nice solid sole so you can use a spade etc, whree the croc rip-offs I use are too soft
    maccruiskeen
    Epoxy point is pretty treacherous in pretty much any shoes. Get a garden sprayer mix some sugar and water and give its a spritz.
    1
    hot_fiat
    That’s why I suggested short wellies. They only cover your ankles. The other option I use is a knackered pair of approach shoes  (or TKmaxx specials) with the laces permanently tied up really loose. Go a complete size up for less faff.
    fazzini
    @blokeuptheroad I have not. Just knew they existed. I live in crocs too as they suit my very wide feet. Like @db I fear they will still fail on painted garage floor…that’s the slippiest surface known to humankind (I have the bruises to prove it)
    1
    davros
    Birkencrocs
    3
    blokeuptheroad
    Thanks all. I’m going to try the all terrain Crocs. Go me! 😄
    ElShalimo
    Any ideas how to remove oil stains from Crocs?
    longdog
    I’d say welly shoes are the way to go, those crocs look no different material wise than regular ones.
    We have welly shoes, actually cut them down a bit more to aid handless on and offs for similar reasons and they’re great for popping out to the bin/recycling, feed the birds, hang washing etc and cheap as chips.
    zippykona
    I once saw a man in crocs carrying a baby across seaweed covered rocks at lowtide .
    Either some sort of gymnast or bloody stupid.
    longdog
    Reminds me, I have some croc sandals I got for when I go to and from home outdoor swimming nearly crippled myself a few times on grass slopes and rocks.
    lister
    I have a pair of very old and knackered Meindl walking boots by the back door. The laces are tucked under the insole and I can just slip them on and off with ease. I can spend the whole day in the garden like that, or untuck the laces and do them up properly when I need.
    thepurist
    These have a non slip sole (think they’re mainly for hospital workers and the like) and don’t have a bunch of holes in the side to get your feet wet when you walk on wet grass and leaves. Soft and comfy sole too, like outdoor slippers.
    https://www.screwfix.com/p/skechers-sk200092ec-riverbound-metal-free-non-safety-shoes-black-size-8/807tv
    blokeuptheroad
    Seems Crocs do two kinds of all terrain ‘clog’. Normal all-terrain and ‘Atlas’ all-terrain.  The former seem to just be moulded with a more aggressive tread pattern but in the same plastic as regular Crocs, the latter have actual rubber on the soles so should be less slippy.
    Expensive mind for what they are, especially as I’ve had to buy Mrs Bloke a pair too! However, I discovered my Defence Discount Card gives me 30% off on the Crocs website which took the sting out of it.
    alric
    you need these
    They might not be easy to find if youre over size 42, and comfortable theyre not, but for slippy muddy mountains jungles and rivers theyre all the rage
    MoreCashThanDash
    And if you are popping out after dark….
    Up to 50% Off
    highlandman
    How about these from Lomo, perhaps go up a size ..?  the soles are pretty grippy.
    3mm Wetsuit Booties | Lomo Watersport UK. Wetsuits, Dry Bags & Outdoor Gear.
    blokeuptheroad
    Up to 50% Off
    🤩 what a time to be alive!
    1
    ffati
    You need a pair of these
    https://www.birkenstock.com/gb/boston-oiled-leather/boston-core-oiledleather-0-eva-u_5326.html https://www.birkenstock.com/gb/boston-oiled-leather/boston-core-oiledleather-0-eva-u_5326.html
    always used to wear crocs but was fed up of them wearing out and becoming death traps. These maybe 3 times the price but a year down the line they are still looking good and the grip is well good
    1
    sandwicheater
    I’ve been dropping hints i NEED a pair of ATC’s for a while.
    Yep, true story.
    dovebiker
    I’ve got a pair of these – pretty chunky, water resistant and ideal for trudging about:
    https://www.sportpursuit.com/catalog/product/view/id/2669664
    CountZero
    Merrell do a Croc-adjacent shoe with better styling, I’m thinking about getting a pair. Merrell Hydro-Mocs.
    1
    bigblackshed
    I have a pair of the Merrell Hydro-Mocs. They are hideous. Because the sole is a pattern copy of the Vibram sole that’s on other Merrells, but made from the same material as Crocs, they are slippier than a greased frog. They are not as easy to slip on and off as Crocs, but that makes them more secure.
    Your dignity and self esteem have plenty of drain holes though.
    9481061f-61ca-4d1b-a9c6-ad27a0867f50
    longdog
    £115 to nip out to the bin?! I don’t think so 🤣
    kormoran
    Those merrels! They look like you stood to close to the fire
    redthunder
    Florabest Garden Clogfrom Aldi or Lidl. Job! Jobbed!
    £54 …. For Crocs WTF.But Why!
    funkmasterp
    Seeing as though most of these are basically a collection of holes why not just nip out in bare feet. It’s free and very easy to do!
    scruffythefirst
    Yup, bare feet here. If there’s snow on the ground I might resort to flip flops. Neither are very protective when welding or wielding hammers.
