Leaking Shimano Cal...
[Closed] Leaking Shimano Calipers - possible solution
Folks,
I think a few of you have posted over the last few years of leaking calipers from various Shimano brakes. For me it has been their RS785 road caliper, three calipers and counting replaced under warranty.
My rear one is starting to go the same way again.
The symptoms are a gradual loss of power and contamination of pads and discs. It is a very small leak, barely visible but still noticeable in small deposits of oil on the caliper.
Along with many I thought it was the piston seals that were leaking and as there is no seal kits available not a serviceable part.
My current caliper is out of warranty so I decided to do a quick Google search to see if there was any updates on this issue before I bought a new caliper. I found a post from a guy called Oliver Majewski who diagnoses the problem as a rubber o ring seal on the fluid transfer port. He says that if you replace the o ring with a slightly harder rubber compound it fixes the issue.
I have ordered some new O-rings and will give it a try.
Certainly from inspecting one of my previously failed calipers the deposit of oil is close to where the port is as opposed to the pistons.
Worth a try before you junk your caliper. Easy to do, remove caliper, remove the securing bolts to split the caliper, replace o ring, re assemble.
Regards
Posted : 28/04/2017 1:46 am
Might give that a try at some point on my slx brakes that have a similar problem.
Posted : 28/04/2017 4:22 am
Taging to check back later
Posted : 28/04/2017 4:53 am
ohhhhhhh....... O ring sizes?
Posted : 28/04/2017 5:03 am
Make sure you get the correct material as well.
Posted : 28/04/2017 6:31 am
Is anyone able to post a link to this page? I am failing miserably.
Posted : 28/04/2017 6:35 am
Ordered replacement 785 calipers yesterday. Where did you get the correct size and type o rings from spangels?
Posted : 28/04/2017 7:01 am
Second hit in google for me.
Posted : 28/04/2017 7:23 am
I use xt calipers with my shimano hydraulic levers. No issues. Best brakes I've ever had. Faultless so far (touch wood)
Posted : 28/04/2017 7:37 am
Re o ring size had to measure them with calipers, however will wait until they arrive before I confirm they are right! Will let you know.
Posted : 28/04/2017 7:51 am
Are they the same as the bleed port seal at the leaver?
Posted : 28/04/2017 8:00 am
Okay after a bit of trial and error I have found the closest size but slightly thicker o rings.
It is 3mm internal diameter and 1.5mm width. The original ones are 3mm 1.3mm. Will fit the modified caliper tomorrow and post if it works or pisses fluid everywhere.
Regards
Posted : 04/05/2017 10:05 pm
Any update on this ?
I've almost got my AWOL sorted now, it has RS785s and they are [i]awful[/i]. I'm suspecting the same issue that you've seen.
Posted : 08/05/2017 12:42 pm
Hi not had a chance to put the caliper on the bike, hopefully get it done later today.
Regards
Posted : 08/05/2017 1:45 pm
Nice weather for it! keep us posted please 🙂
Posted : 08/05/2017 2:16 pm
Hmm, interesting - my RS785s have been perfect for nearly 2 years (apart from one seizing, but that was my fault). I fixed the leak on my XTs by replacing the hoses with Uberbike ones. Slightly more expensive method, but you replace the seals in the process and can choose hose colour 🙂
Posted : 08/05/2017 2:27 pm
That doesn't change the transfer port o-ring though?
Posted : 08/05/2017 6:34 pm
Cured the leak completely, that's what matters.
Posted : 08/05/2017 6:56 pm
This thread needs more 'likes'.
Posted : 08/05/2017 7:29 pm
Aye DezB but not the type of leak that's being discussed.
Posted : 08/05/2017 7:55 pm
Okay, so got the caliper fitted today. Brake bled with no issues, checked for leaks and none apparent. Cleaned the discs and sanded the pads and after a couple of bed in stops the brakes are working to full capacity with no more squealing.
So the new o ring has done the job and only time will tell if it is better than the original one.
The o ring you need for the RS785 caliper is this one
http://www.ebay.co.uk/itm/141455807147?_trksid=p2060353.m1438.l2649&var=440603744128&ssPageName=STRK%3AMEBIDX%3AIT
I will keep the thread updated on how it is performing over the next month and post up if it fails in the next year or so.
Regards
Posted : 08/05/2017 8:30 pm
Can all shimano calipers be split to do this or is it only certain models? Had trouble previously bleeding some brakes, wandering if this could have sorted a possible issue with them?
Posted : 08/05/2017 8:39 pm
I would think as long as it is held together with bolts you should be able to split it. Not sure if they are all the same design inside and I think they may have differing o ring sizes though I could be wrong.
Posted : 08/05/2017 8:42 pm
Three weeks on and the o ring is holding. In the first week there was some squealing from the brakes but that was just some residual contamination. It has gone now and the brakes are stopping well with no issues.
A cheap fix if you have the same issue.
Posted : 03/06/2017 10:11 pm
 Rik
Just checking in
Posted : 03/06/2017 10:32 pm
Trying to resist starting another thread on this so here goes:
After a frustrating discussion in the LBS I'm not sure they will be willing to warranty the (probably) leaking calliper on my dad's bike.
One line they stuck to as a reason why it couldn't possibly be a leak is that the lever travel hadn't increased. I tried to explain that on an open system brake, a small leak at the calliper wouldn't necessarily lead to an increase in lever travel (not immediately at least) but by this point the shop owner had already shown he didn't actually know how open system brakes work, so I was on a hiding to nothing with that argument... 🙄
Aaaaanyway, point being, has anyone with a problematic leaking caliper suffered from increasing lever travel, or is it just squealing/poor performance?
Posted : 08/09/2017 3:24 pm
If it's a tiny leak, why would it necessarily lead to increased lever travel? I've certainly had cases where it feels perfectly normal at the lever, with contamination plenty and howling at the caliper.
Can you clean them thoroughly, then wrap a bleed block with clean tissue and see if you can get it to piss some mineral oil out onto it by squeezing the lever repeatedly?
Posted : 08/09/2017 3:33 pm
My thoughts exactly Martin, was fairly sure a small enough leak would just behave like pad wear!
It's the usual warranty gong show whereby I can't *prove* it's a leak but I'm not willing to keep replacing pads and discs at my own cost when there's no other obvious solution...
edit: had tried the step with a bit of tissue paper and a bleed block between the pistons, couldn't produce any fluid, don't know if it's dependent on temperature or something. Was sure I'd read that the leaks were so small that it wasn't possible to detect the usual way...
Posted : 08/09/2017 3:43 pm
Try doing it keeping the lever slightly squeezed/under pressure for a longer period, e.g. overnight. You could use a cable tie or a bungee cord wrapped around the grip and the lever several times to maintain the pressure on the lever.
Posted : 08/09/2017 6:01 pm
It isn't always that seal though, we've seen several that have been leaking around the caliper piston seals themselves, so something to watch out for.
Posted : 08/09/2017 7:13 pm
I've had about 5 micro leaking deore callipers over the years, lever travel not affected and still feels solid.
Interesting about the o-ring, I'll bear that in mind for the inevitable next time.
Posted : 08/09/2017 9:17 pm
OK, I take it all back, not sure why I was so certain I had tested caliper for leaks, but took pads out this evening and they more or less had fluid running down the back of them! The inside of the caliper looked pretty gloopy also.
Hopefully this persuades the shop that there's a problem, although they were adamant there *couldn't* be a leak as the levers felt solid... 🙄
Posted : 08/09/2017 9:25 pm
As above.... I have had quite a few shimano calipers leak.
I have taken a couple apart and examined the piston surfaces on a microscope and could clearly see a slight angled groove around the circumference of the piston from the square o ring seal.
A lot of people don't realise (I am sure you all do) that the pistons don't actually slide through the seals under normal braking. They only slide when the pads wear and they need to advance further out the caliper.
It's the square o ring that deforms under pressure (and relaxes as the pressure is removed) . If the calipers are not perfectly aligned then the pistons and square o ring can develop accelerated wear due to uneven loading around the circumference of the piston. Had it happen to my m785s which use ceramic pistons and also deores which use ally pistons. Once the grooves develop the pads wear unevenly accelerating the problem further.
I think the problem is worse the more worn the pads get and the further the piston needs to advance out of the caliper. I have had deores leak from the piston with worn pads, but fitted new ones and problem went away (not surprising as the seal was then running on an unworn surface).
Posted : 08/09/2017 9:49 pm
Not sure what the shop's problem is with this one, we've sent loads of these back to Madison, and they've all been replaced/credited with no quibble at all (given the usual provisos of "proof of purchase needed", and "2 week turnaround as very busy"). It's a common problem, we've got no reason to argue over it, and just fit a new caliper from stock, then get it credited by Madison once their warranty department get to it.
Posted : 09/09/2017 7:23 am
Yeah I was surprised. Also surprised that they denied ever having heard of any problems with leaking Shimano calipers, although to be fair, every shop I've spoken to has denied any knowledge of the issue, must be a Shimano cover-up! 😉
Posted : 09/09/2017 8:04 am
Agreed some people seem to be lucky but this does seem to be an extremely common problem not related to any particular level either (lx,deore,slx,xt etc)... Mind you I have not heard of the xtr's going very often... Perhaps that has to do with the slightly tighter tolerances on the magnesium cast and machined caliper body. Either way madison should warranty without question and the lbs should not be arguing.
Posted : 09/09/2017 8:12 am
 pdw
Has anyone had/fixed this on Rs505 calipers?
I'm having a nightmare with mine at the moment. The odd thing is that it gets better with riding. As soon as you get some heat into them they stop squealing and start working. But then leave the bike on the rack for a week or two and they're squealing again. Similarly, attacking the pads with a heat gun sorts them out nicely, but the problem comes back without riding the bike.
So I don't know whether there's fresh oil being leaked onto them, or whether the pads are soaked through and I'm only ever burning off the top layer and then it's soaking back to the surface when left.
The problem started with both brakes at exactly the same time which makes me suspect an external source of contamination rather than both developing a leak simultaneously.
Posted : 09/09/2017 10:11 am
..that's exactly what was happening with my R785 caliper, drag the brake down the first big hill to cook it and it was fine for the rest of the ride but it was squealing again if I didn't ride it for a week or so.
Never had an issue with increased lever travel but the back of the pads always looked like this..
[img]
Had the same calipers front and rear but it was only the the front that was the problem.
After I'd replaced the pads a few times and decided it was nothing I was doing wrong, I went to my LBS who sorted a new caliper under warranty without question.
Posted : 10/09/2017 10:30 am
 pdw
Interesting - thanks for the info.
Was out for a long ride today and checked the brakes afterwards, and absolutely no sign of a leak. Also tried wrapping some paper around a bleed block and giving it a good squeeze and again, no sign of leaks.
Posted : 10/09/2017 9:11 pm
I'd run out of ideas with the RS785 callipers on my Arkose, but took the plunge last night, pulled them apart and changed the fluid transfer port O-rings.
The rear calliper had a lot of oil around the inside of it, which I think had been leaking from that point, as the back of the pads didn't show and signs of the piston seals leaking.
I get everything spotlessly clean when reassembling them, and fitted new G02A pads front and rear. 20 mile test ride today (including some careful bedding in) and they are the quietest they've ever been, with good power front and rear.
Will report back after a couple more rides to confirm how they are holding up.
Posted : 24/09/2017 9:02 pm
. The reason XTR calipers don't suffer so much is that the lever seals give up the ghost so quickly that the caliper seals don't have a chance to fail first .
Posted : 24/09/2017 10:24 pm
 pdw
freeagent - where did you get the O-rings from?
I need to pull mine apart and find out what size the RS505s take.
Posted : 25/09/2017 9:48 am
Sorry for the delayed response - O-rings came from Ebay - there is a link on P1 of this thread.
So, 2 weeks in, I've done a total of about 100 miles over 4 different rides, and the brakes are both silent and powerful.
Posted : 08/10/2017 9:33 pm
Bookmarking this thread, just in case. Good work.
Posted : 09/10/2017 1:17 pm
Nitrile also goes by the most commonly used trade name Buna-N, which should help those trying to source them from alternatives.
As a side note Nitrile/Buna-N is also the O-ring material for the vast majority of suspension components. As it is resistant to mineral oils/greases, hydraulic fluids (HFA, HFB, HFC), solvents and relatively flexible at low temperatures 😉
Posted : 09/10/2017 6:50 pm
Finally gave up with the front caliper. Despite putting a new o ring it has continued to leak. The rear one is still fine though.
Bought a Hope RX4, bleed was a bit more of a faff compared to the original but having done it once I could make it a bit easier next time round. You will need a threaded syringe for the caliper.
Riding it is good, braking is more powerful than the shimano one. There is less lever travel which given the original has a long lever throw is not a bad thing.
Will replace the back one if it fails too but happy to keep it on into then.
Posted : 24/12/2017 8:28 pm
 robo
Really useful post, I've got the same problems with leaking 785 calipers and will try replacing the o-rings before splashing out on some RX4s.
Would someone mind confirming the replacement o-ring size, is it 3mm x 1.5mm?
cheers
Posted : 28/12/2017 8:08 pm
 kcr
Just fitted a new 105 hydraulic groupset with 785 calipers tonight. Front brake working nicely, squeezed the rear lever and...drip, drip, drip on the garage floor. Oil freely leaking around the ceramic piston. The bike hadn't even got off the workstand!
From a quick search, there seem to be a number of people reporting leak problems with these brakes.
Posted : 07/04/2018 2:19 am
Yep, the problem still exists, only yesterday afternoon I had a brand-new bike, straight out of the box with a caliper that had shat itself pretty badly. All nuts and bolts tight, no trace of fluid on the outside, but the pads and pistons were swimming. We keep a stock of calipers for replacing these, as if we didn't, somebody would end up having to wait for their new bike, which never looks good for anyone involved.
Posted : 07/04/2018 9:06 am
Yip, same here. Mine were leaking from the centre o-rings as mentioned above. Fixed that but now they leak via the piston. Can't find any reference to fixing that issue so it's a warranty return. PITA.
Posted : 07/04/2018 9:45 am
Just sorted my 785s with new o rings.
Initial problem sorted so thanks OP :0)
Posted : 27/06/2018 8:40 pm
To revive this thread did anyone post a link to the correct sized O ring? I found lots at 1 mm but nothing as close as the found. Any suggestions, and yes, I have googled for it.
Posted : 10/01/2019 9:57 pm
 JAG
It was on the first page - to eBay 😀
Posted : 11/01/2019 11:46 am
My rear RS505 did this. Very slow warranty through Canyon. 6 weeks later got the replacement, put it on, new pads, bled up nicely, freewheeled down the road, back working nicely. Used the front to come to a stop, GOBBLEGOBBLEGOBBLESHREEEEEEEEEIIIIIIIIIKKKK. Oh look, the front has failed after 6 weeks of hard sitting around doing nothing.
Never had a Shimano brake, was going to buy some for another bike. Not a chance now. Total crap.
Posted : 11/01/2019 12:18 pm
Anyone got any more pics of what these leaks look like or is it always seen like this? Image is from earlier in the thread
Posted : 16/01/2019 11:03 pm
Had endless joy with Shimano brakes and now think this is happening on my cx bike. Oily rear disc.
The Hope looks soooooooooo nice.
Posted : 16/01/2019 11:21 pm
The o-rings linked to on the first page are the original 70shore not 90 as recommended in the guide. How are the ones in the link holding up for everyone?
Posted : 20/01/2019 12:33 am
Interesting, I have this problem, I guess a simpler fix might be to seal around join between the two halves with something, might work for my commuter anyway.
Posted : 20/01/2019 10:46 am
Loctite anerobic flange sealant. I've used this on crankcase mating surfaces several times and never had a problem with leaks. It goes on as a liquid, the surplus stays liquid and can be wiped away. The remainder between the sealing faces goes off and forms a seal. Whether or not this would effect a seal in a hydraulic circuit remains to be seen. Might be worth a try.
Posted : 20/01/2019 11:05 am
I have just ordered M7000 complete replacement for my old M785s. If I can't flog them I will strip and try the suggestion above with the seals from ebay at the back (I think the front leak is from the piston rather than the caliper halves).
Posted : 20/01/2019 12:11 pm
My son Harry is frantically searching for a new set of brakes at a good price (he is 12). His Old Shimanos were squealing so badly it was getting painful to be near him so I replaced them with an old set of Avid Juicy 5's. He hates the look of the Avids (apparently this is important to a 12yr old) so he is now all over the internet showing me good deals on new shimano brakes. Is there a model where the leaking seal issue vanished and was never spoken of again? I am guessing that any good deals we find will be a potential squeal issue again?
Posted : 17/07/2019 9:22 pm
Just bumping this in an effort to placate my son and also not raise yet another thread on the subject 🙂
Posted : 17/07/2019 11:39 pm
They don't appear to have solved it yet, judging by the brand new Tiagra caliper in our workshop that's dribbled it's internals away before it's even made it out of the shop. I'd be taking a look at a Clarks M2 set(probably less than £50 a pair inc rotors & mount on the internet), we've sold a lot to replace worn out brakes, rather than repair them, and had no issues other than a damaged olive in one set. They're very reasonably priced, work well, look nice (to me, obviously subjective), and even have "go fast" red anodized bits.Edit- £42.99 on Amazon.
Posted : 18/07/2019 8:37 am
And this isn’t just about infrequent use and the o-ring on the transfer port.
My 9020 callipers (single piece, no transfer port) which have been on my commuter for 4.5years, in almost daily use have finally developed the same symptoms as my Trail brakes did on the MTBs. Time for some RX4s...again.
Posted : 18/07/2019 8:55 am
I was going to suggest the Clarks brakes as they look ok in black with the red anodised bits on them. Go 180mm discs and when the pads wear out something in a bit more grabby.
Otherwise I’d be looking to find a deal on Sram Levels or some
Maguras - maybe mt2’s or mt4’s.
There are still loads of posts about leaking shimano brakes - the only ones that don’t have loads of leaks reported seem to be the 4 pot caliper ones.
Posted : 18/07/2019 9:08 am
I got some of the Clarks ones for £20 and end for my daughter's bike. Theybwork well, but clearly not as much bite as an expensive set. Doesn't matter so much when you weigh 28kg but it might when you're 82kg. Fine for commuting tho too I'd imagine.
Posted : 18/07/2019 9:14 am
Thanks everyone, will take a look at the Clarks. He needs something decent as he is moving on to red trails now so I want him to be able to manage his speed effectively, that said, to the point made by @molgrips, he weighs half my weight so a lot less to stop 🙂
Posted : 18/07/2019 11:03 am
He’ll prob be ok with the Clarks if he’s quite light - especially with 180mm rotors. The sram or Maguras I suggested will likely be more powerful (you could add Sram guide R’s to the list as they seem to come up cheap from time to time) and better overall.
Posted : 18/07/2019 8:03 pm
I'm nearly 13 Stone and my Clark's m3 on 180 rotors are more powerful than my mini monos
Posted : 18/07/2019 9:21 pm
Use shimano mtb calipers instead the road calipers.
Posted : 18/07/2019 10:01 pm
I’ve had this issue with Rs505 (x2) and (Road) 785s, annoyingly even though I’m on here a lot I’ve just been buying new calipers.
Paul’s cycles weren’t great with the RS505 caliper the first time so I just replaced it myself and the other bike was way out of warranty so I didn’t bother. It was getting expensive in terms of pads initially as I thought it was just Road oil contaminating the pads and discs.
Posted : 18/07/2019 10:49 pm
Just came on here to post on this same issue and this thread appeared. God bless STW!
Posted : 19/07/2019 2:05 pm
As someone with a few sets of Guide RS that need repairs, I wouldn’t recommend these to someone looking for troublefree but otoh, the fixes are easy to install and cheap and easy to source (piston seals under £5 a calliper and lever piston in Alu plus seals around £7 a go both on eBay).
I’ve moved to Magura. The power is there, reliability hasn’t been an issue yet but lever feel is quite different than Shimano which will put many off I think (no ‘instant power’, there’s a noticeable progression through the pull).
Posted : 19/07/2019 5:00 pm
Bump
Posted : 16/09/2020 7:15 pm
Clarks brakes which use mineral oil like Shimanos do spare piston seals for their clout and M3 brakes. The pics look like the shimano square cut seals. i wonder if they'd fit any shimano pistons ?
Posted : 17/09/2020 11:38 pm
I’m not really up on my model numbers but would the O ring listed on page 1 fit an XT calliper?
Posted : 23/10/2020 8:53 am
A more general suggestion for the wider topic is to try using an MTB caliper. I've been using a old 2 pot XT on the front of my roadie for over 6 months and it's been so much better - not only in terms of no leaks or contamination of pad, but it doesn't chirp or rub the disc and feels much smoother.
I've got a Hope RX4 ready to fit and some new Galfer rotors, but am scare it might be a backwards step!
Posted : 23/10/2020 4:16 pm
My 785 calipers were not very good . Replaced the o ring and whilst it stopped them from making too much noise , their performance was a bit rubbish . Replaced with some XT and it is brilliant .
Wish I did it sooner .
Posted : 23/10/2020 4:49 pm
Has anyone seen O-Rings that fit Saint calipers?
Posted : 23/10/2020 5:40 pm
Hey thanks for the o-ring info. Useful.
I work as a shop wrench, and have had plenty of leaking Shimano calipers over the years - and had one of my own brakes too. Never tried to fix them myself, as Shimano Nordic has always warrantied the calipers with minimum fuss and fast too (give em a call or email and couple days later its sorted), but nice to know it may be possible to fix the calipers as well.
Nevertheless, I have been riding exclusively Shimano brakes for 17 years now (after some Hayes back in the early 2000s), and have had one faulty caliper. Though my own brakes are always aligned right, unlike many of the customers brakes. And at the moment my oldest in-use Shimanos are XT 765s that I got when they first came out...
Most of the leaking ones from customers have been the low end ones (sets priced around 50-80 euros), but several SLX / XT ones as well.
Posted : 14/01/2021 6:30 pm
