Is it safe? Answer ...
Is it safe? Answer our reader survey questions
15 Users
 Mark
Level: Black
We've created a page here where we have created a collection of simple survey style questions. Unlike normal surveys this one gives you the results ev ...
By mark
Get the full story on our front page at:
https://singletrackworld.com/wp-content/uploads/2022/09/is-it-safe-answer-our-reader-survey-questions/
);min-height:50px">
Support us from less than £0.06/day and help us keep the content flowing by becoming a full member.
Posted : 12/09/2022 7:32 pm
 Mark
Level: Black
The original thread seems to have borked itself from page 2 onwards and won’t play nice. Tech are looking at it but in the meantime let's continue here.
Posted : 12/09/2022 7:37 pm
Is this the right thread?! Anyway, survey is done. Unsurprising demographics 🙂
One thought - the answers to membership levels might be a bit skewed given your recent request for help. If it weren’t for that my answer would have been “No and no plans to be”. Depends what you want to do with that data I guess, but maybe weight the full membership count using new members in the last month or so.
Posted : 13/09/2022 7:56 am
Did it but surely you don't expect middle-aged keyboard warriors on a MTB-site to own a MTB? 🙂 🙂
I used the detail for my last MTB but I'm solely gravel and road now
Posted : 13/09/2022 8:28 am
Survey done.
“ Unlike normal surveys this one gives you the results every time you submit an answer.”
Just like Pinkbike does?
Posted : 13/09/2022 8:33 am
How often do you ride bikes?
I actually had to drive to work yesterday. I had forgotten just how dreary driving is.
Posted : 13/09/2022 8:35 am
I'm pretty sure I should report this - clearly mark is just spamming the forum with duplicate threads and starting new ones when the previous one gets closed. Treats it like he owns the place he does.
Where are the mods when you need them eh? Too busy keeping up with the QE thread I guess.
Posted : 13/09/2022 8:40 am
I'm quite surprised to see (at the time I did the survey) the majority taking the survey are male, middle aged, have high incomes and own quite a few bikes costing upwards of £2,000 each (and more). It kind of sounds like golf or something. Long way from Klunkers, jumpers for goal posts etc 🙂
Posted : 13/09/2022 9:10 am
I'm not sure you can make that second leap from the survey.
Given the age range is average 41-50 and that many households are going to have at least two people earning (possibly more, especially in lower income households where multiple renters is common) it doesn't need much to tick into the "higher" brackets (unless the distribution has changed most were in the up to 100k bracket).
2 forty ish year olds on median salary aren't far off that bracket, add in a teenager with a Saturday job and you're into that one.
Also the gender pay gap is wider at higher age groups so "male and 40+" is going to heavily skew the average wage upwards too (though likely in the same households one of the other earners will be female in the same broad age group so household income tends to be closer to the median)
4 people on 39 hours at minimum wage puts you in the same bracket and isn't unlikely if those 4 people want to "make rent" in a lot of places.
Source:
Ages 16-17: £10,910
Ages 18-21: £17,284
Ages 22-29: £24,600
Ages 30-39: £30,865
Ages 40-49: £33,477
Ages 50-59: £31,358
Ages 60+: £27,508
From https://occaminvesting.co.uk/average-uk-salary-by-age/
Posted : 13/09/2022 9:25 am
I knew STW was mostly grumpy middle aged blokes but I never realised just how much it's mostly middle aged grumpy blokes 🤣
Posted : 13/09/2022 9:32 am
 Mark
Level: Black
Yeah, sorry for the forum thread glitching and chaos.
On the gender split data I have something to share to the group. For some of the self reported data we are seeing we already have other sources. On the demographics for instance we have our Google sourced data. This is the snapshot from the last 30 days as reported by Google Analytics for both age and gender. I offer this for the group to discuss but initial comment is that the age data seems to correspond to the user reported data in the survey but 'so far' the gender split does not.
Posted : 13/09/2022 9:57 am
 Mark
Level: Black
And one more cautionary point. So far the survey page has been open for slightly less than 24 hours. Our analytics show that it was viewed 691 times yesterday. Yesterday we clocked up 120k page views.
Posted : 13/09/2022 10:07 am
I probably broke the thread yesterday - you were probably deleting my post while I was editing it! Sorry about that, and the post. 🙂
FWIW - I'm logged in today and it's allowing me to fill it in again (if I were inclined to, I haven't though).
Posted : 13/09/2022 10:14 am
 5lab
I’m not sure you can make that second leap from the survey.
Given the age range is average 41-50 and that many households are going to have at least two people earning (possibly more, especially in lower income households where multiple renters is common) it doesn’t need much to tick into the “higher” brackets (unless the distribution has changed most were in the up to 100k bracket).
its also worth noting that the graph has tighter bands for lower incomes than for higher. The stw median is around £78k, mean is around £87k (with some assumptions around actual values within a banding)
Posted : 13/09/2022 10:16 am
offer this for the group to discuss but initial comment is that the age data seems to correspond to the user reported data in the survey but ‘so far’ the gender split does not.
So "40 something blokes on a high wage" are significantly more likely to be filling their work day completing surveys on the internet than less will paid or female counterparts?
I don't suppose that's a surprise to anyone.
Posted : 13/09/2022 11:07 am
 nuke
Id believe the survey over GA given you don't 'tell' GA your age and gender...so certainly interesting to see how GA and survey compare
Posted : 13/09/2022 11:24 am
 Mark
Level: Black
Interesting. We have another source of data which is our full membership database and I can say with confidence that the current self reported data is very different to the gender split for those that receive the magazine.
Posted : 13/09/2022 11:28 am
So “40 something blokes on a high wage” are significantly more likely to be filling their work day completing surveys on the internet than less will paid or female counterparts?
I don’t suppose that’s a surprise to anyone
Work smarter, not harder 😀
Posted : 13/09/2022 11:29 am
Mark, I'm genuinely curious as to how GA works out the gender of the reader - is it based on other site visiting habits? Do we tell them some other way somehow? Curious how it's done...
Posted : 13/09/2022 11:47 am
https://www.google-analytics.ie/blog/how-does-google-analytics-track-user-gender-and-age/
Would probably be a good source - can't say I've read it mind
Posted : 13/09/2022 11:53 am
 Mark
Level: Black
Google knows a lot about us all and its exact methodology is not exactly in the public domain, but AI and machine learning comes into it, a bit like how your politics can be assumed from your browsing habits. In general it knows who you are if you have a gmail account, which is the biggest email sub group on the internet. I imagine it uses its Gmail data and extrapolates from there. I'm making educated guesses here but other data we get from Google Analytics does correlate well with our own data and other data sources. For example, I imagine none of us have explicitly told Google how old we are and yet their age profile up there does correlate quite well with our own data and indeed is, at this early stage, correlating reasonably well with the self reported data.
Posted : 13/09/2022 11:56 am
I think everyone with a Google account has haven't they?
Posted : 13/09/2022 11:57 am
Harvesting data for what purpose?
Posted : 13/09/2022 12:04 pm
On the gender split data I have something to share to the group…
Perhaps both are accurate? Women are far more likely to search for and read content than to be members and add to the forums’ content?
Posted : 13/09/2022 12:10 pm
took your survey, but if i try to look at it i get an error message - no such key So I've no idea if its gone through or not.
Posted : 13/09/2022 2:28 pm
