That is all.
Hmmmm, let’s see you buy the material of your choice, plus lining, plus the material for doing the top part where the fittings go, properly measuring up, cutting, machining, and getting the whole thing done correctly first time, oh, and having the space to lay everything out, and a really good machine to sew them with.
I’ll give you a clue: a good machine could cost you a couple of hundred quid for starters.
A good friend of mine is a trained seamstress, I know how much work goes into even a simple little job, to make certain it’s done right first time.
That skill takes years, and doesn’t come cheap either.
And a really good pair of curtains could easily last thirty to forty years…
Now let’s see your attempt at doing it.
