Home › Forums › Bike Forum › "improved" products that make **** all difference
- This topic has 104 replies, 61 voices, and was last updated 9 years ago by Northwind.
coatesyFree Member
I take it that nobody else has come across the new 148mm (nope, not the old 150mm) rear hub yet.
tom200Full Member650b
This. Apparently the slowest wheel size, excuse me while I pmsl 😆
whatnobeerFree MemberThis. Apparently the slowest wheel size, excuse me while I pmsl
50 seconds in – no difference. That should of been the end of the video.
15mm front axles definitely get my vote, nothing wrong with 20mm, possibly even a downgrade.
Pressfit BBs also get my vote, no need at all, maybe easier for manufactures, but a pain in the arse for consumers, and I doubt many folk will notice any increased bb stiffness.
Disc brakes on road bikes – no need at all. Get ride of them and you also don’t need through axles or any other nonsense.
somafunkFull MemberI’d beg to differ……..Disc brakes on road bikes offer consistent braking in use, independent of weather conditions. Press fit bb’s could be said to come about due to a move away from the standard round tubed triple triangle frame design towards the modern multi pivot full suspension design with its need for increasing stiffness, larger seat and down tubing needs a larger BB Area to weld to, that’s not to say some variants of press fit designs are not sub par but the underlying concept of a larger crank axle is valid.
I could offer an opinion regarding axle size but shrug…………
jools182Free MemberWere moving all our bikes to tubeless as default rather than tubed (currently the lowest end are tubed) because it’s so much less hassle than fitting tubes irrespective of any other benefits
I thought they were much more hassle to fit than tubes
Compressor or track pump to get them seated etc
reggiegasketFree Memberfront and rear maxles definitely make a difference. I run a Trek Remedy and I’ve tried a QR rear end and a maxle rear end, with everything else the same, and you could easily tell the improvement.
What I think is a duffer is split gear cable outers. Why not run a full length? This is what I now do on all my bikes and it’s tons better.
SannyFree MemberExternal bb designs
Press fit bottom brackets
Press fit headsets
1 x 10 or 11 dedicated chainsets
Mahoosive rear rings the size of a traditional big ring
Electric shifting
Enduro specific saddlesOn the positive side, things that I think are a good thing are and a real improvement
Wider rims
TRP Cable disc brakes
Wider handlebarsCheers
Sanny
HansReyFull Memberstuff that annoys HR
-press fit BBs
-customisable geometry (e.g. anglesets)
-tubeless
-super thin inner tubes
-15mm and 20mm hubs. I have a wheelset for each, qould prefer just onestuff that pleases HR
-external threaded BBs
-marzocchi suspension
-regular inner tubes
-bolt thru axlesbigrichFull Memberif you don’t notice the improvement with tubeless, your pressures are wrong.
dirtydogFree MemberUsed to run 25f/30r psi with tubes, any lower and I would be at serious risk of pinch flatting/denting rim, now I’ve gone tubeless I run 25f/30r, any lower and I would be at serious risk of denting the rims.
takisawa2Full MemberChrist, I could take my bike on Antiques Roadshow.
I don’t even have QR skewers, nutted axles here. No suspension, 25.4 bars, straight steerer, skinny steel frame, threaded BB, & my brakes work via a cable.
I need to get with the in-crowd. 😀jameswilliams54Free MemberUsed to run 25f/30r psi with tubes, any lower and I would be at serious risk of pinch flatting, now I’ve gone tubeless I run 25f/30r, any lower and I would be at serious risk of denting the rims
I struggle not to see the adadvantages, I used to find dozens of thorns when seasonally changing my tyres in lincs and now in the peaks I spend my time either getting bitten to death my midges in the summer or freezing my as off in the winter waiting around for people with punctures.
From my experiance in the last 5 years I have only had one puncture and that was when I was using a spare wheel with a tube in it.
toys19Free MemberI feel genuinely sorry for all the bike component designers and manufacturers if this is what their customers actually think of their efforts. These people actually put a lot of passion into making great products so we can have more fun for longer.
Luckily you lot just represent a small section of luddite curmudgeons.
Its all about incremental gains, each small thing seems like not much, but when you add together modern geom and components you get incredible bikes.
If you put Fabien Barel on a bike from 2005 and one of todays wonder machines he would be light years faster on the new bike.whitestoneFree MemberThere’s a balance to be made between a technically perfect solution; one that can be manufactured at a reasonable cost; one that is maintainable and one that is usable.
The first attempt at something is rarely perfect, I can think of only one product in that category that I’ve used (the Petzl Zoom headtorch) and it’s hardly changed in 30 years. Any changes have been down to consumer feedback rather than marketing hype.
Every manufacturer would like their product to become the standard, ideally of course with everyone else paying them royalty fees to use it. Unfortunately while they are all jostling for position we, the consumer, are left in the fall out zone. Some changes are hard in that you can’t retro-fit them to an existing bike/frame: tapered headsets would be an example. Others are soft in that they require little change on our part: tubeless tyres; wider handlebars.
Unless we, the consumer, say “hang on, this is a pile of ..” then the cr*p will prevail.
PJM1974Free MemberI feel genuinely sorry for all the bike component designers and manufacturers if this is what their customers actually think of their efforts. These people actually put a lot of passion into making great products so we can have more fun for longer.
I want to see whoever it was who decided we needed another front axle standard (15mmx100mm instead of the 20mmx110mm that’s been around for yonks) put in the stocks. I’d also like to see the waste of a job who’s now decided that we need 15×110 front axles – remember that 20mmx110mm is going to be stiffer – removed from the industry in disgrace.
I don’t mind new standards and improvements if they genuinely bring benefit, however just lately we’re having things foisted upon us that are extremely cynical attempts at planned obsolescence at worst or extremely poorly contrived marketing at best. No-one wins, least of all the likes of Giant, Trek and SRAM who are on my “avoid” list.
mikey74Free MemberRegardless of the size (I have both 15mm and 20mm), screw through, quick release axles are a vast improvement on QRs. Stiffness is a secondary issue IMO.
whitestoneFree MemberMate with a new bike with press fit BB.
me: “what’s so good about it?”
him: “It’s stiffer so you get better power transfer.”
me: “So, can you tell the difference?”
him: “Err, no”Emperor’s new clothes …
mtbtomFree MemberSome of these things work better for me, personally than others. Not saying it’s true for everyone!
* tapered steerers – I’m riding around on a 160mm fork that weighs as much as a cross-country fork from 2005 and as stiff as a downhill fork from the same era. If the tapered headset is an enabler of this, I’m in!
* thru-axles / maxles (front or rear) – all good with me, it’s a much better engineered system. No longer do I get that ‘zing-zing’ of the disc rubbing at the back. No stupid little spring to lose if you accidentally undo the QR too far when changing a puncture on the trail.
* external BBs – I’ll take the trade-off reduced life-span for for the simplicity in fitting. No-more crank pullers, no risk of the mounting surface wearing and the crank constantly coming loose. I spend many times more every year on tyres than I do on BBs.
* tubeless – again, another win for me personally. Almost never puncture these days, where I used to get a lot of thorns.
Not a fan of push-fit BBs. Doesn’t seem to be any longevity advantage and replacing them is terrifying.
mikewsmithFree MemberTapered? Works well for me +1 for mtbtom’s comments about 160mm forks out performing old DH for old XC weights.
Thru Axles? Simplicity of them is great though the 1/4 turn one in the Manitou is taking a bit of getting used to. 15mm? Works fine for me too
Ext BB’s moving on from Shimano to Hope has removed any of the wearing out problems.
Tubeless? Slow to get to but never going back, real TR rubber and real rims make a difference.
My bars are wide and stiff, it feels much better than the pokey 680mm bars I had, if I hadn’t tried them I wouldn’t be able to appreciate how much better they are.
Dropper posts – no brainer
1x with a 10-42 range it hits what a lot of bikers need and want.
It’s all going well for me.
continuityFree Memberany lower and I would be at serious risk of denting the rims.
Are you riding on road bike tyres?
Nearly everything in this thread is of huge benefit to cycling.
Especially tubeless.
Shit, even press-fit BB’s. Yes, they lower manufacturing costs. Yes, they require an additional special tool to remove/affix. Yes, they reduce wear and tear on BB’s so they last longer. Yes, your new bike is now cheaper to buy as some of the manufacturing costs saved are passed on to the buyer. How do you think that is a bad thing you moron?
RorschachFree MemberI feel genuinely sorry for all the bike component designers and manufacturers if this is what their customers actually think of their efforts. These
peoplecompanies actually put a lot ofpassiontime and marketing into makinggreatslightly different products sowe can have more funthey can make more money for longer.mikewsmithFree MemberThese people companies actually put a lot of passiontime and marketing into making great slightly different products so we can have more fun they can make more money for longer.
My mech snaps or wears out, now I can have one with a clutch and improved range over one that was available in 1990. Life is crap isn’t it.
vincienupFree MemberOn the disc brake road / cx thing, bolt through front is one solution, the other is simply mount the brake on the right hand leg, forward of the fork instead, like Cotic used to do. IMO it’s a neater solution and gives a cleaner cable run also.
I’ve never actually heard of a front wheel being ejected under braking force, but don’t want to experience one. Through axle front on a CX looks like a PITA compared to a Shimano skewer and sensible design, to me…
PJM1974Free MemberYes, they reduce wear and tear on BB’s so they last longer.
Nope. I’ve killed the press fit BB on my new Stumpy in fewer than four months.
I even managed to eke out longer from a Race Face BB, which hitherto set the brown standard in BB longevity of five months. Shimano XT BBs last me upwards of eighteen months.
continuityFree MemberNope. I’ve killed the press fit BB on my new Stumpy in fewer than four months.
Guys! Listen! I’m one guy in a mass of satisfied customers! If I had a problem it has to be the norm! My opinion is important!
Think about it for one second. The same bottom bracket can be made to press fit into a shell as one that screws in. The only thing that changes is where the BB is mounted. In one, it is away from muck, sand, water and shit – on the other, it is right in the firing line.
Still a moron.
showermanFree Memberim feeling happy no one has said anything bad about my fattie within the first few posts yet
BruceWeeFree MemberI think if there’s one thing you can’t say about fatties it’s that they ‘make **** all difference’ 🙂
vincienupFree MemberI thought most BB issues came down to care (pressure washing) or installation?
I’ve had no real issue with RF or Shimano external bb’s, and when the plastic pressfit in my Zesty finally gave up way after everyone said it would, I got a Hope PF, although I know there are others with similar metal not plastic solutions for this.
showermanFree Memberstrava off road. all it has done is show land owners the routes we use when possibly we should not
philwarren11Free MemberPress fit BB’s. Anyone who thinks they’re good has never owned one.
NorthwindFull Membervincienup – Member
You must not have owned a Truvativ BB
nickcFull MemberPress fit BB’s. Anyone who thinks they’re good has never owned one
[shrugs]
there’s one on my Shan. I’ve not noticed any change over my last ext.BB. genuinely can’t get bothered about it.
molgripsFree MemberTubeless is great – noticably faster for me. And no more trouble than tubes IF you have the right setup.
I actually insisted on 15mm maxle for the bike I just built up. Would rather have the extra security now it’s available.
PJM1974Free MemberNope. I’ve killed the press fit BB on my new Stumpy in fewer than four months.
Guys! Listen! I’m one guy in a mass of satisfied customers! If I had a problem it has to be the norm! My opinion is important!Think about it for one second. The same bottom bracket can be made to press fit into a shell as one that screws in. The only thing that changes is where the BB is mounted. In one, it is away from muck, sand, water and shit – on the other, it is right in the firing line.
Still a moron.
Not sure why I’m a moron – is it because I’ve killed a bearing in four months, or that I don’t happen to agree with your expert analysis of the engineering superiority SRAM PF30 bottom bracket?
For the record, the bearing is held in place with a plastic retainer, which flexes – hence the well known issues of creaky cranks and bearing wear.
Or of course, you could have used Google
And yes, when I’ve spent upwards of £2.5k on a bike then I do feel that my point does matter especially when it seems to be shared with a number of individuals.
Unlike you, I’ll refrain from personal insult, so I sincerely hope that your experience with PF/BB30 is better than mine.
The topic ‘"improved" products that make **** all difference’ is closed to new replies.
