Home › Forums › Bike Forum › I seem unable to set saddle height, any pointers?
- This topic has 47 replies, 25 voices, and was last updated 1 month ago by jameso.
deanfbmFree Member
Flat pedals. 810mm inseam, 400mm shin. Been suffering with bad lower back for a year due to pelvic imbalances. I noticed the pattern that my back gets worse every time I go for a pedal, not bad, but just thought it was in the realms of “well, I just have a niggly back so it’s just part of it”.
My way of doing it has been heel on pedal method for years, knee almost locked out at max extension, doing this I ended trying a saddle height of 755mm/915mm (BB to saddle/top of pedal to saddle) yesterday, I was sure this wasn’t too high because I could back pedal with the heel on the pedal maintain contact for the full revolution. I had been running 740mm/890mm for a while, but something was feeling off, so decided to try higher to find that ceiling of too high.
It appears that I’m unable to “feel” when a saddle is too high except when it ruins my back, my lower back is spasming and tight after yesterday’s trial. The feel of the higher saddle was extra strength, ie I was at least 1 gear harder up the same steep hill. I did my best to try to “feel” my hips rocking but couldn’t detect it.
I’ve plugged my figures into a bunch of calculators and found –
Lemond – 715mm/875mm
Hanley – 723mm/883mm
CS Bikes – 697mm/862mm
Canyon Bikes – 713mm/872mm
Specialized (Shin Length) – 734mm/894mm
Now set my saddle to – 715mm/865mm
How does my new saddle height look? I’m erring on the side of caution on account of my back, lower (to a degree) should be better for my back, right?
What “feelings” am I looking out for to tell if my saddle is at an optimum height?
chiefgrooveguruFull MemberYour old saddle height seems really high for your leg length! What length cranks do you have?
1diggeryFree MemberI’ve always found lower better than high for me.
I’ve recently went lower on my road bike and went faster for longer with more comfort – opposite of that I always thought from old school macho stuff.
Higher gives all sorts of problems with overextending, including rocking of the pelvis to reach the pedal.
Lower starts to manifest itself in my knees.
I just got there with trail and error or bracketing. Say 735 star (that was mine not saying that you that). Try that, try +5 and -5 then work towards the best feeling. I have all my bikes from enduro to road at the same height. Can quite happily pedal my enduro with the seat partly dropped for a good distance.
Maybe also adjust seat seatback as seat angle and height affects that.
Bear in mind that crank length, and pedal and shoe stack are also variables that some calculators don’t account for.
1inthebordersFree MemberIf you think it’s too high, lower it while on the ride.
Is it ‘flat’ to the ground, where on the rails is it, what Reach & Stack has your bike, what width bars etc etc.
Tere are too many variables and TBH the stretch leg to heal is only what I use to initial set the saddle height, I then adjust it while riding proper trails with all my gear on.
I’m guessing with only a 800mm inseam you’re quite short – 5’4″-5’6″? I’ve a couple of pals I ride with who are short and when following them, both have saddles too high (and roll their hips).
forkedFree MemberIf you’re sure your inseam measurement is accurate, then a 755mm saddle height does sound much too high.
The Lemond method also puts saddles too high, in my experience.I’d start at 700mm and go from there.You may need to relearn to pedal as I imagine you’ll have been compensating technique to deal with the high saddle.deanfbmFree MemberI’m 178cm.
Measured my inseam with the book against the wall method.
Yeah, I can’t feel if it’s too high.
inthebordersFree MemberI’m 178cm.
Ah, short legs for height – so probably a high stack?
KahurangiFull MemberIf your saddle is too high then you are probably rolling your hips to help, hence back issues. Get a professional or someone to watch you and/or bike fit.
1chiefgrooveguruFull Member“I’m guessing with only a 800mm inseam you’re quite short – 5’4″-5’6″?”
I’ve got riding mates with that kind of leg length who are taller than me and I’m almost 5’11! Humans vary a lot in their proportions.
I’d start down near 700mm (I run 750mm saddle height at 850mm leg length with 165mm cranks and flats) and put it up 5mm a ride and see how your knees (too low = bad) and your back (too high = bad) feels after each ride, not during.
There’s a reason we stand up for max power but if you’re trying to get that much power seated you’re going to have problems – when we stand to pedal with straighter legs the whole body can move so the lower back doesn’t get hit with weird loads from the pelvis.
mjsmkeFull MemberFlexibility, foot length, cleat/pedal position are also factors to consider too.
Had lower back problems when I couldn’t touch my toes. A few weeks of stretching cured that. Saddle was a little high too so lowered about 5mm but the back paid was cured from stretching before then.
3sl2000Full MemberI love how @chiefgrooveguru not only knows his saddle height (of course he does) he also knows his riding mates’ leg lengths. I’m picturing him in the car park at the beginning of rides sneaking up behind people with his tape measure 🙂
deanfbmFree MemberI also think inseam length is wildly open to measuring errors and methods, my measured inseam is with a 10mm thick book, feet shoulder width apart, I can measure up to 84cm feet together, 84cm again with with a flexi tape directly on the inseam. I imagine a wide book similar to saddle width would read lower too.
I do think inseam has got to be one of those things like height, you bias towards bigger, because that’s “better”, right? So there will be a tendancy to err o the side of bigger.
Then thinking about it even more, shouldn’t “cycling” inseam be measured in a light hinge from floor to sit bones?
YakFull Member715 doesn’t seem wildly out tbh. I’m shorter and run 720. Mrs Yak is the same as me and runs 709. We all vary massively though. What’s your flexibility like? Glutes, hamstrings etc? Core strength good? If after everything you can’t get it right, consider a bike fit. You might have an imbalance that may need correcting.
thisisnotaspoonFree MemberI’m 165mm cranks.
Mechanically it would make sense to pair short cranks with a lower saddle set back on the rails a bit because the bit you’re interested in is the force you can produce at the ~3 o’clock position, so it doesn’t make sense to raise the saddle with short cranks.
Unfortunately we’re in the middle of a trend for 78deg seat angles and people squeezing 200mm droppers into bikes they don’t fit with. So either I’m wrong or MTB’ers are fashion victims.
2jamesoFull MemberFor MTB I’d say 710mm to start with. The Lemond Method of 0.883 X inside leg is good. ime it can feel a bit low for some for a road bike and for the MTB I’d go 5-7mm lower, but as a starting point it’s the formula that seems most generally useful imo. Lemond method -5mm gets you 710mm. I don’t believe adjusting the saddle height for crank length is so important if we’re only talking +/- 5mm of crank, as the main power stroke of pedalling is where the crank is closer to level than vertical, but you might account for it to some extent in fine tuning.
Having said all that the Lemond method came from road riding on a 73 seat angle and a ~15mm layback post. MTBs now pitch you much further over the BB which makes the same saddle height feel different but in terms of pedalling dynamics you’re pedalling around the BB axle so it doesn’t matter once the STA is the same relative to the ground (steeper climbs off-road).
If you measure your sitting height (sit bones / flat surface you sit on to top of head) and subtract from your height you get the same number as your inside leg, to within a very small margin of error. The sit bones are roughly level with your crotch as measured with a book put into the crotch with some pressure, measured against a wall. But since the exact area of sit bone / pelvis you rest on changes with upper body angle (and saddle type I expect) I think IL is a better way to go.
2IHNFull MemberIt appears that I’m unable to “feel” when a saddle is too high except when it ruins my back, my lower back is spasming and tight after yesterday’s trial.
Can’t you just try dropping your saddle height incrementally until it doesn’t ruin your back?
jamesoFull MemberMechanically it would make sense to pair short cranks with a lower saddle set back on the rails
The slight adjustment of the saddle rearwards makes sense I think. It felt good for me at first when changing to 5mm shorter cranks on the road but in the end I went back to the original position as saddle position is about my CoM over the wheels/bike as much as pedalling dynamics. But that’s just me, I don’t seem to be too sensitive to exact saddle to pedal relationship as long as they’re the right distance apart. For others the X – Y of saddle to crank has to be right to prevent issues.
Good Q. Pedalling can feel a lot more natural at the right saddle height when your hamstring and general flexibility is good. It can make a good saddle height start to feel like it may be a bit low but that’s a good sign imo, it should feel relaxed and neutral.
That could be tight hamstrings pulling on your hips and causing lower back tension. Lower your saddle and if not already doing something like this try some basic regular stretches most days for a few weeks (just a touch-toes stretch is ok to start)?
1scaredypantsFull MemberIf your saddle is too high then you are probably rolling your hips to help
and
2stanleyFull MemberI’d start at the lower end of the range. But you need to do a few rides without adjusting anything and keep notes. After 4 or 5 rides, check your notes and then make one change at a time. Repeat the process.
Hip flexion angle isn’t affected by seat height alone. This could be reach, stack, saddle set-back, poor flexibility, poor core strength, poor technique, etc.
A much better bet would be to pay to see a bike fit expert. They will analyse your knee, hip, other angles whilst you pedal. This is a quicker and more accurate process. Although it is still likely that you will take a few rides to adjust to the new position.
chiefgrooveguruFull Member“I love how @chiefgrooveguru not only knows his saddle height (of course he does) he also knows his riding mates’ leg lengths.”
Obviously I have some kind of laser device for this! 😉 Or we just occasionally ride each others’ bikes and I’ve been confused at how low the saddles are for riders my height or taller…
Does anyone else slide back on the saddle when they want maximum seated pedalling force (not necessarily power, I think it’s a lower cadence thing), so you can drive through the pedals using your hamstrings etc more, a bit like a deadlift?
deanfbmFree MemberCheers for the feedback everyone.
Realistically, am I going to get an “mtb” bike fitter? ie someone that gets steep seat angles, nose down saddle for climbing steep stuff?
I think it is fair to say I have been running my seat significantly too high.
I would say my strength/flexibility is good, 15 minute yoga flow concentrating on lower body every day, no problem touching the floor, normal plank over a minute and side plank over 30s is no bother. Do bodyweight/kettlebell bits most days.
jamesoFull MemberDoes anyone else slide back on the saddle when they want maximum seated pedalling force (not necessarily power, I think it’s a lower cadence thing), so you can drive through the pedals using your hamstrings etc more, a bit like a deadlift?
I’ve noticed how a slacker STA on my single-speed is ok for low cadence grinding power climbs – generally it seems that a slacker STA or saddle position helps lower cadence power and steeper is better for spinning along.
n0b0dy0ftheg0atFree MemberInseam-10cm is usually a starting point for me for BB to saddle top.
1PJayFree MemberI’m not a technical rider, just a pootler, so probably don’t count, but I find, that like saddles themselves, it just comes down to what feels best rather than numbers.
Pick your rule of thumb of choice and start from there, make small changes as an when you decide that your current position isn’t right. Fore & aft position also counts where lower back comfort is an issue &, counterintuitively, sometimes being more stretched out can help. Whatever your attack position, I gather that you’re looking for a natural ‘lazy S’ position for your back. I’ve often heard it said that you need a position you can hold for some time without your hands on the bars.
As a terrible fiddler of bikes, I’d also suggest giving each position you try a decent run in terms of saddle time & mileage (bodies do adjust).
I ride flat pedals and like a position where my heel is fractionally lower than the ball of my foot at the bottom of the pedal stroke, it lifts me from the saddle a tiny bit when I’m pedalling hard.
inthebordersFree Membernose down saddle for climbing steep stuff?
Nope, never – mine are always plum level on all my bikes (road-gravel-XC-Enduro) and as I’m out of proportion (long, long inseam vs average body/arms) I also run with the saddle well forward too.
mertFree MemberFWIW i have an 810 mm inseam. And a 710mm saddle height.
That’s got me round rather a lot of races on and off road. And several ten thousand plus mile seasons.Even weirder, i’m now on 165mm cranks… with a 715mm saddle height.
Don’t forget your set back either, that can have an impact with things like hip angles and reach etc.captaintomoFree MemberHow does your foot rest at the bottom of the stroke? Is it flat or are your toes pointed down? Toes pointed down indicating saddle too high. Every bike fit video that I watch they all tend to say that the original saddle height was too high.
BadlyWiredDogFull MemberDoes anyone else slide back on the saddle when they want maximum seated pedalling force (not necessarily power, I think it’s a lower cadence thing), so you can drive through the pedals using your hamstrings etc more, a bit like a deadlift?
See also layback seatposts on road bikes. My take, fwiw, is that pedalling efficiency and handling effectiveness/weight distribution have become slight divorced on mountain bikes, so saddle position is less about pedalling effectively and more about your position on the bike. Even if you wanted a layback seatpost, very few dropper posts are anything other than in-line. The slightly agricultural Specialized Command post is the only one I can think of, off the top of my head anyway.
Steeper seatpost angles put the saddle further forwards, good for climbing, but throws more emphasis onto your quads rather than your hamstrings. Or at least that’s how I understand it and also my personal experience. Hamstrings more effective. So yes, sliding back on the saddle will do as you say, at least up to a point.
chiefgrooveguruFull Member“Steeper seatpost angles put the saddle further forwards, good for climbing, but throws more emphasis onto your quads rather than your hamstrings. Or at least that’s how I understand it and also my personal experience. Hamstrings more effective. So yes, sliding back on the saddle will do as you say, at least up to a point.”
Yes! I’ve noticed that when I’m really going for it I’ll stand up and stomp until my quads get too fatigued, then sit and drive down through my heels, and repeat. There’s also the sit and spin a lower gear approach but that doesn’t work on my singlespeed!
“I ride flat pedals and like a position where my heel is fractionally lower than the ball of my foot at the bottom of the pedal stroke, it lifts me from the saddle a tiny bit when I’m pedalling hard.”
If I’m really squeezing out maximum force my heel is quite a way below the pedal at the bottom of the stroke – I guess I’m trying to straighten the knee and open the hip as much as possible. I’m never having to reach with the forefoot/toes – whenever that happens on a bike I know my back will complain because my hips will be rocking.
1tall_martinFull MemberHave you considered asking your mates how it looks as you ride and possibly a a bike fit?
I had a bike fit for my road bike. Not cheap at £200 but i couldn’t do some rides because of knee pain.
The (road race based shop) lowered my stem which wasn’t a surprise but they lowered my saddle loads.
I’d been pedaling about on tip toes for years and that has been fine until I hit my 40’s and did some 130 mile rides.
My road riding mates then said they’d always thought my saddle was too high. £200 well spent!
Photos are in the wrong order. It’s first, last and second
YakFull MemberI don’t know about mtb bike fit. Mrs Yak had a bike fit done to deal with some pain (it worked), and I use that as a basis for setting up any type of bike for her. On a typically steeper seat tubed mtb, that means sliding the seat back or using a layback post. The only mega specific road thing I don’t do is shimming one of the mtb shoes like the road shoes.
1zinaruFree Memberive used this method forever and never had any issues. (not even sure where i picked it up from)
in your riding gear and shoes, lean the bike against a wall, pedal backwards (if your running flats, the ball of your foot is just in front of the axle) and place your finger on your hip bone.
saddle too low – your hips rock, too high – your hips rock. the sweet spot between is when your hips dont rock.
i can even feel a difference when wearing different shoes or bibs/shorts.
13thfloormonkFull MemberA much better bet would be to pay to see a bike fit expert. They will analyse your knee, hip, other angles whilst you pedal.
Hmm, I have less faith in bike fitters than I used to, between two of them, both well thought off in the Scottish central belt, I ended up with a saddle height of 780mm (well, 779mm…) but over time I’ve gradually lowered it to 760mm and feel faster and more comfortable than ever.
I wouldn’t even trust inseam measurements other than as a starter for 10, I doubt they tell you anything about e.g. tight hip flexors or piriformis or tight/weak low back muscles.
If in doubt, drop it 10mm!
TiRedFull MemberLemond works for me with 74 cm saddle height and 84 cm inseam. But I ride my TT bike 2 cm lower than this. Always are on the side of lower is better and it’s hard to do damage from under extending but not vice versa. There are other variables like reach but it’s a decent starting point.
1mertFree MemberHmm, I have less faith in bike fitters than I used to
I have almost none. Much like coaches, it’s become far too easy and unregulated to do a couple of basic online courses, get yourself set up and get a website/facebook page running. Couple of “glowing testimonies” from those with zero biomechanical quirks and then boom, it’s £120 for a 90 minute fitting. Or 50 quid for a months coaching plan, copy and pasted from an online resource with some random bits jiggled around.
2wheelieFull MemberThis works really well on all my bikes https://www.youtube.com/watch?v=rI9IBtS5YTE&ab_channel=RoadCyclingAcademy
TiRedFull Membercouple of basic online courses
My badges cost a lot more. But I don’t charge 😉
Position over the bottom bracket matters. If you are too far back then a lemond or other formula will lead you to be over extended. Can lead to exterior knee pain and ITB irritation. I like to see how the weight is taken when pedalling to set fore and aft position, together with saddle height. If it feels to stretched, lower a cm and move it forward half a cm. See how that feels.
To be honest, we fret a lot, but humans aren’t THAT variable. In general. There are exceptions, but they are relatively few.
deanfbmFree MemberKicking around the idea too of going down to 155mm cranks, they can only help everything, right? All my joints going through a smaller range of motion.
chiefgrooveguruFull MemberI’ve found that (shorter) 165mm cranks help my bad knee a lot – but I have a very faulty right ankle with limited mobility (I can’t do trampolines or bouncy castles, or as I’ve just discovered, unicycles). If you don’t have anything structurally wrong with your body I’d suggest you don’t need to go to even shorter cranks.
