Singletrack's forums are sponsored by...
Forum sponsored by Saracen
How well does a 30....
[Closed] How well does a 30.9>31.6 shim work?
11 Users
Offline  jamesgarbett
Share this post
New frame is 31.6
Existing dropper is 30.9
But I've just found a unused USE shim in the spares box
Before I fit the internal dropper will this wafer thin shim actually keep the post from slipping?
Posted : 09/05/2020 3:01 pm
Offline  frogstomp
Share this post
Yes (probably). A bit of carbon paste will also help if you feel you are having to tighten it too much.
Posted : 09/05/2020 3:05 pm
Offline  warpcow
Share this post
I used one for years without issue.
Posted : 09/05/2020 3:08 pm
Offline  tomhoward
Share this post
This. And just about to use one on my next frame/dropper.
Posted : 09/05/2020 3:12 pm
Offline  Shackleton
Share this post
I've been using one for a year. Some slippage necessitates adjusting post height every other ride. I suspect whether they work or not is down to the relative tolerances of the 3 parts (frames, shim and post). Luckily my reverb has just died so I can buy a proper sized one.
Posted : 09/05/2020 3:23 pm
Online  cp
Share this post
I used one for a couple of years with a dropper. Absolutely fine, no issues at all.
Posted : 09/05/2020 3:24 pm
Offline  LAT
Share this post
I’ve used one with carbon paste. No issues at all.
Posted : 09/05/2020 4:25 pm
Offline  martymac
Share this post
I use one on my normal post, to avoid buying a new one. No problems at all, no slippage, i weigh around 120kg.
Posted : 09/05/2020 4:36 pm
Offline  munrobiker
Share this post
I've used one and it was awfully creaky on one bike, fine in the other.
If you raise and lower your seat post a lot they get mashed quickly as they're so thin.
Posted : 09/05/2020 5:30 pm
Offline  hols2
Share this post
I've never had problems with them. Sand the inside of the shim so it's not slippery, wipe the seatpost down so it's not greasy. I've never had a seatpost slip.
Posted : 10/05/2020 2:37 am
Offline  winston
Share this post
No problems here. Had one on my fatbike and it's worked with both a dropper and a thud buster with no issues for 18 months.
Posted : 10/05/2020 9:20 am
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
