£300k for a ford escort?? I know inflation has been nuts but seriously?
If I had that much money to spend on a restomod, it would be the Alfaholocs 290R. But I never will so good luck to them.
Did either of you read the article? They’re limited edition custom built cars from the ground up, they aren’t ‘restomods’, there are no original parts from Ford in them, and they aren’t built by Ford, but they do have chassis numbers that continue from the last RS Mk1’s. Which is why they’re ‘Continumods’. Yes they’re expensive, but when you can have a 2.1ltr 4-cylinder that revs to 10k and produces nearly 300bhp, and all the other stuff that goes into it, they justify the cost – try putting one together from scratch. The shell alone has been completely re-engineered for stiffness, for example.
If you want a cheaper one, you can buy new body shells, and build one from scratch, but it’ll never match one of these for quality.
