Home Forums Bike Forum Hope Pro II Evo hub query
Viewing 13 posts - 1 through 13 (of 13 total)
  • Hope Pro II Evo hub query
  • fudge9202
    Does anyone know if the shimano freehub for the Pro 4 hub will fit the Pro II Evo hub
    whitestone
    Check on the Hope site, they have exploded diagrams of the hubs. If both freehubs have the same part number then it’s likely that you can swap between hubs. Might need the seals to be the same as well.
    mudmonster
    There is a video about the pro 4 hub. I’m sure they mention making the rachet ring bigger and then as a consequence had to make other parts bigger.
    clubby
    Sorry, it won’t fit. Rear Pro 4 hub bits all different from pro 2 evo.
    johnw1984
    Clubby is right, I found out the hard way last week at BPW. My Evo 2 freehub had 2 shattered bearings and the shop sold me a Pro 4 by mistake.
    Still waiting for my refund a week later….
    fudge9202
    Cheers for that saves me making the same mistake, hub has an xd driver on it so may as well run 11 Speed
    andyl
    nope, definitely wont fit.
    Someone will probably swap for an XD driver but I would stick with it and go for a SRAM GX cassette for £35. The end caps on the XD driver side are slightly smaller diameter to let you slip it on after fitting the cassette. If you buy some new end caps to change the axle type you will either need to get the driver side one turned down slightly or Tweeks stock the XD driver specific ones separately.
    Vortexracing
    I have a brand new Shimano 11 speed pro2 Freehub I want to sell if that helps
    ta
    Dave
    fudge9202
    Dave I’ll pm you
    johnw1984
    I used the opportunity to change the broken aluminium one for a steel one.
    Should have just gone Sram XD, but would have needed to get the end cap, cassette and freehub.
    fudge9202
    Dave I’ve messaged you
    Yea for me I’ll need a new cassette, derailleur and shifter but is it worth changing from 1×10 11-40 to 11 speed, will I notice a considerable advantage?
    Vortexracing
    Messaged back Fudge
    fudge9202
    Dave pm you
The topic ‘Hope Pro II Evo hub query’ is closed to new replies.
