Home Forums Bike Forum Help – headache – Reducer headsets
Viewing 25 posts - 1 through 25 (of 25 total)
  • Help – headache – Reducer headsets
  • foxyrider
    Situation:
    New frame: head tube = tapered = top 1-1/8, Bottom 1.5
    Old Forks 1/18
    Headset = fully integrated (no cups)
    Will a Hope Combi Internal Headset work?
    I dont think you can get integrated converters can you?
    davidtaylforth
    Dunno, what frame is it?
    foxyrider
    Felt Edict – integrated head set – tapered – need to run my 1-1/8 sterrer in it?
    dhrider
    Sounds like the frame has 44mm top ID and 55mm bottom ID.
    Should be this which you need : http://www.chainreactioncycles.com/Models.aspx?ModelID=41851
    foxyrider
    No that’s a semi-integrated system isn’t it?
    davidtaylforth
    Could you not buy a 1/18th – 1.5 integrated headset (I dont know exactly what size you need but you need to measure the diameter of the bit where the bearings sit in the frame) Then buy a suitable reducer crown race to suit?
    dhrider
    44mm top is semi integrated and needs pressed into the headtube.
    Measure the internal diameter of the headtube and let us know….
    If it’s 41mm or 41.8mm it’s road style integrated so you will need to find out if it’s cane creek or campag fit. These would have the bearing set into the headtube rather than pressed in.
    foxyrider
    Its a road system – “fully integrated” – so its just bearings only system – no cups – I would thing you woud either need a 1-1/8 insert or as you sa a suitable 1.5 to 1-1/8 crown race step down?
    @dhrider – I don’t think you can press fit a semi-integrated cup into a integrated head tube?
    The frame is this and I have not bought it yet just planning ahead?
    http://www.feltbicycles.com/USA/2011/Mountain/Edict/Edict-LTD-Frame.aspx
    davidtaylforth
    If you buy an FSA 1 1/8 – 1.5 headset then theres a good chance one of their reducer crown races will match the lower bearings?
    What headsets do the bikes come with complete?
    dhrider
    No, you can’t. The diameters are different!
    Not many MTB frames use a road style tapered integrated headtube hense the confusion and difficulty of finding the right headset!
    dhrider
    Looks like you need something like http://www.chainreactioncycles.com/Models.aspx?ModelID=59620
    BUT with a reducer 1 1/8″ crown race.
    foxyrider
    Yeh excatly DH – Hmmm – damn
    dhrider
    Since you got a new frame just buy some tapered forks 😉
    Problem solved!
    foxyrider
    PePPeR
    Get the frame supplier to provide the correct headset at the same time, problem
    Solved 😉
    foxyrider
    Its just I am trying to use a 1-1/8 fork in a frame designed to take a tapered steerer but is integrated 🙁
    davidtaylforth
    Why cant you just do what I said and use a reducer crown race?
    foxyrider
    I can’t find one – however I did use the Cane creek Heaset finder:
    Your Headset
    Based on the information you have provided, your headset falls within the tapered standard and requires:
    Top Headset:
    SHIS:IS41 – 1-1/8″ Cane Creek Integrated Threadless
    Bottom Headset:
    SHIS:IS52/30 – 1.5″ Integrated (IS) to 1-1/8″ Conversion
    http://store.canecreek.com/products/productdetail/40.IS52/30.Bottom+Assembly/part_number=BAA0087/1739.0.1.1.45652.0.0.0.0?pp=25&
    davidtaylforth
    eh? what about it?
    foxyrider
    Found it:
    http://www.singletrackworld.com/forum/topic/titus-ftm-carbon-anyone-got-one-from-on-one-yet
    Its a 1.5″ bearing with a reducer ring/crown race 🙂
    Ordered from http://www.bike-mailorder.de/ for £28
    davidtaylforth
    Im lost.
    Do you know the bearings in that headset fit the diameter of the frame your intending to buy?
    foxyrider
    yes – David – its an IS 1.5 – the cane creek headset finder gave me the result (see above) which is the same as the Titus carbon frames which the others have had a problem with. It is not an ISi.
    Basically the frame comes with an IS integrated tapered headset. The top I can keep but the bottom I need to alter to use a 1-1/8 steerer. So above will slot into the bottom IS 1.5 but reduce to 1-1/8 internal diam for the steerer as it comes with a reducer crown race.
    davidtaylforth
    Great stuff, I struggle cos I cant view half of these links. But I see the numbers 41 & 52 in your post up there which Im assuming are the OD of the bearings and hence your frame must be the same so it’ll al probably work out rather nicely.
    foxyrider
    yup – happy now 🙂
The topic ‘Help – headache – Reducer headsets’ is closed to new replies.
