Home Forums Chat Forum heat storage one for the wood burners
Viewing 11 posts - 1 through 11 (of 11 total)
  • heat storage one for the wood burners
  • trout
    question of heat storage for the wood burner .
    situation is I put a wood burner in early this year and it’s in a small alcove
    with approx 4 inches clearance around the sides and the walls get very hot
    but while they are lined with heatproof board I was thinking if I put some iron or other metal
    around the fire it would store the heat and release it when the fire went out.
    the question is
    aluminium is a good conductor of heat. so would heat up fast
    would it be better to use some material that heated up slower to give the heat back slower
    what would be the best material to line the cavity with to heat up and then slow release it
    I was thinking cast iron bricks. if such a thig existed
    Edukator
    Something with a high heat capacity and fairly low thermal conductivity. Rock for example.
    nickjb
    Something that conducts slowly. I’d have thought something like stone/concrete as that is what is in storage heaters. There was a greenhouse storage heater on some TV show that used a pit full of broken glass.
    trail_rat
    Build a semi conductor thermocouple driven fan and force the heat round your room/house.
    Controller for my heating still isnt plumbed in so the stove and ecofan are doing a sterling job of heating the house atm
    lump
    Run a water coil in the flue, that runs to 1/2 radiators on the second floor. Try and reuse heat recovery from the flue
    RustyMac
    I can see where you are coming from trout, you would surely need to use something like the bricks from a storage heater or something.
    Thinking from a different direction, could something like an eco fan help? my thought would be it would help distribute the heat round your house better heating the core of your house (walls and stuff) which would store the heat for you.
    davidjones15
    If you’re losing heat during the night, after the burner has done its job, try reducing the heat loss in these areas.
    Bricks from storage heaters would do what you want.
    matt_outandabout
    I placed gritstone slab @4″ thick under and @1″ thick each side and back, with some insulation behind. It was ace, like a massive storage heater – still warm the next morning – and well worth doing.
    Edukator
    Heat recovery form wood burner[/url]
    trout
    Like the bricks from a storage heater idea
    not wanting to heat other rooms as we both like the bedrooms to be cold
    Stoner
    Decent thermal mass will do it.
    There’s a new range of stoves I saw that make the most of that principal with cermaic cores.
    But you could make a fan like I did, cost about £20 and it’s not great but was a fun exercise and probably works to a point, or go for a proper one, Eocfan http://www.ecofan.co.uk/
The topic ‘heat storage one for the wood burners’ is closed to new replies.
