Home Forums Chat Forum Heat pump thread
  • This topic has 176 replies, 61 voices, and was last updated 1 week ago by nixie.
Viewing 17 posts - 161 through 177 (of 177 total)
  • Heat pump thread
  • prezet
    My sister’s new ASHP install was costing her a tenner a day this last week.
    Easily done! I turned ours on during the cold spell last week and it was closer to £13 for a days electric.
    Bear
    Don’t make such big changes, go for a couple of degrees and leave it for a few days, ideally in cold weather.
    Bunnyhop
    For those of you who’ve had an ASHP fitted, did they make much mess? Also how many fitters were on the job?
    Sorry I haven’t read the whole thread.
    1
    surfer
    We had 4 fitters (4 vans) on site for 4 days then 2 for 2 days. They had messed up during their survey day so basically replumbed the whole house. They expected 5 days max. Weren’t too messy although I had to take up carpets later to improve the way they had refitted the boards and I have to patch some walls where they channeled out to fit additional rads, that was expected so no complaints. Our house was almost all 8mm microbore so had to be ripped out, we expected the inconvenience so no problem. If you have larger bore piping it may not be necessary but you may need additional radiators after the heat loss calcs are done.
    1
    alanl
    It all depends on who is fitting it. If I was doing it, there’d be little mess, and what there was would be cleaned up every day. I work on my own, so take longer fitting it, changing from a gas boiler to a ASHP would take me, typically, 5 days, with a few rads changed too. If its a full pipework change, easily 10 days work.
    I’ve read reports of others doing it in 2 days.
    molgrips
    Octopus are now offering in our area. It gave me a flat rate of £3000 after the grant, regardless of what extra work needs doing.
    On the one hand this is great, but I am planning to change the rads myself and I’m fairly sure I won’t need anything else. I’d that’s the case I don’t want to pay the flat rate. I think I’ll contact some local installers. I want to get it to come in under the £7500.
    1
    trail_rat
    Have you requested the weather to do the same ?  We can be +5 and -15 on consecutive days .
    Is it really like having a storage heater again ,?
    littledave
    Just starting my third winter with an ASHP, still like it 🙂
    molgrips
    I’ve been planning to replace rads, I did the central areas of the house last year, now I want to do the living spaces. I’ve been working on making them slightly wider and double panel which will roughly double the area. This will make the current boiler much more effective and efficient. However the rule of thumb seems to be that for a heat pump you want 2.5x the area.
    However, I think that the original rads were oversized when run at 80C, because the house was really warm. Even as they are I can run the boiler at 55C or even 50C when it’s mild and 60C when it’s cold. That’s a dT of around 40C. If I halved that, that would mean a flow temp of 40C in the coldest conditions we see would be enough to heat the house – therefore suitable for a heat pump. However there’s a couple of caveats to that calculation. The radiator isn’t the same temperature all the way across, so by doubling the area you’re not really doubling the heat output. However I’m more than doubling the area, but how much heat is output depends on the flow rate, so I’m not really sure how much extra heat I’ll be able to get.
    The other thing to consider is that even at 55C in mild conditions the heating warms the house in say, 30 mins, and then stops for an hour or so. So in theory a heat pump could run at even lower temps for longer or even continuously, and still heat the house. And at the lower temps it could be very efficient and therefore cost less than gas (which is what I want).
    I don’t want to replace these rads and then have to do it again for a heat pump install in the future. But the rads I am choosing now are the biggest I think I can fit in the spaces we have so.. dunno.
    molgrips
    Coincidentally Octopus just called me back to follow up on the quote I requested. She said that they would come and do a survey to verify what you actually need, and if rads didn’t need changing that would knock the price down. She also said I could send photos of possible locations for it.
    This is great service from Octopus, they have an actual knowledgable person contact you and provide follow-up through the process rather than a call centre drone. You don’t have to commit after the survey which is great.
    molgrips
    Octopus have come back with £2,400 after the grant, given that we don’t need any radiators.
    Sandwich
    I visited my dad on Sunday and that was the cost per hour showing on the IHD for his electric panel radiators! He pooh-poohed the ASHP suggestion saying it was too expensive! It wasn’t that cold in Peterborough on Sunday hopefully there won’t be a fierce winter this year.
    molgrips
    Hmm, that quote does not include £800 worth of scaffolding 🙁
    Flaperon
    Hmm, that quote does not include £800 worth of scaffolding ?
    Weird, it was included in mine.
    molgrips
    They just called me back to say that they’d waive it…
    nixie
    We had a heat geek survey on Monday and tomorrow have the octopus one. Fairly certain we won’t be using octopus as I don’t want the rads they will supply (unless I did these first). HG losses were calculated at just over 10kW at -1 (south coast, 21deg room temp). That needed 2 rad changes as apparently the modern column radiators we have are quite beefy.
    nixie
    Hmmm Octopus came up with a massively different 15kW loss (though the surveyor could not tell me at what internal/external temps that value is for)! Definitely no HP from octopus as they don’t offer a model with a large enough output.
