Home Forums Bike Forum Headset properly seated?
  • This topic has 5 replies, 4 voices, and was last updated 5 years ago by 35mm.
Viewing 6 posts - 1 through 6 (of 6 total)
  • Headset properly seated?
  • 35mm
    LBS moved all parts from one frame to another. The headset seems to be a little “uneven”. The pictures are seen from the left side of the bike (right side closer to the rear of the bike).
    Does it matter?
    cynic-al
    If it feels OK it’s probably fine.
    Might be worth checking the various surfaces for anything stuck in there, and the headset cup being in fully.
    samuelr
    Probably the paint on the frame causing the headset not to sit properly. You could ask them to ‘face’ the headtube so its perfectly flat. I would have thought they would have done this already or is it not done any more?
    35mm
    If it feels OK it’s probably fine. Might be worth checking the various surfaces for anything stuck in there, and the headset cup being in fully.
    Bolt in starnut wasn’t really tightened. Don’t think there’s play now. I’ll check the headset cup!
    They said they had done facing.
    I’ll just ride the thing 🙂
    tjagain
    I suspect it will settle in with weight on it and need adjusting. Its certainly not right as is.
    35mm
    Hmm, okay. Rode it pretty fast and hard today. Still the same.
The topic ‘Headset properly seated?’ is closed to new replies.
