Home Forums Bike Forum Headset bearing replacements??
  • This topic has 7 replies, 2 voices, and was last updated 11 years ago by cp.
Viewing 8 posts - 1 through 8 (of 8 total)
  • Headset bearing replacements??
  • stewart4444
    Last time i replaced headset stuff it was before before intergrated headsets became the norm, so now i need new bearings i’m a bit lost.
    I have a kona jake the snake 2011 cross bike with intergrated tapered headset.
    I’m i right in thinking that the bottom option of the link is what i need as a replacement and these are fairly standard and will fit the existing crown race and frame?
    http://www.chainreactioncycles.com/Models.aspx?ModelID=62162
    cp
    A quick google finds the kona spec which suggests your headset is a FSA No. 57-B.
    http://2011.konaworld.com/bike.cfm?content=jake_the_snake
    Googling that brings up the FSA spec
    http://www.fullspeedahead.com/products/290/Orbit-15-ZS
    which says you need 36/45 rather than 45/45 as per your link to ritchey bearings.
    beyond that, I can’t find anywhere with bearings for tapered headtubes in that size!
    stewart4444
    thanks for that CP
    stewart4444
    so opened it up last night expecting to find a sealed cartridge bearing with numbers printed on the side helping me choose a likely replacement.
    to my suprise i discovered an open loose bearing type!!
    Also the surface within the frame that the bearing move on are pitted.
    Surely this most be a semi intergrated headset and i sure be able to replace the cups, as if not the frame is finished?
    Looks like a trip to a bike shop.
    i hate the mine field that has been created in headset.
    Convential press/Bash in cups makes more sense.
    cp
    weird. did you buy the bike new? If they are indeed loose bearings, then it sounds like a bodge to me! Any pics?
    Can you see a cup in the frame?
    stewart4444
    aye brand new.
    i wonder if the number 57 is sealed bearings and the 57-B is the OEM loose bearing crap type.
    It does look like the cup is a serperate piece to the actual frame.
    Eg, the material in the headtube is rough until right at the very top just under the bearing race there is a ring of shiney machined metal.
    Seems to fit totally flush within the head tube so no where to jam a rod and bash out other than on the backside of the bearing race it’s self.
    I’ve have a couple of phone style pics but no idea how to upload from computer?
    cp
    email em to me and I’ll take a look – address in my profile.
The topic ‘Headset bearing replacements??’ is closed to new replies.
