groupset upgrade (r...
[Closed] groupset upgrade (road)
9 Users
Got some cash for Xmas so thinking of upgrading my 105 5700 10-speed gruppo to the latest 11-speed version from Merlin.
I currently have an 11-28 cassette & I'm pondering the 11-32 version.
I ride in the Pennines/Dales/Lancs/Cumbria/Peak etc. so hilly, only had one hill (Mytholm steeps) crack me, will I really need a 32 & what are the drawbacks of a wider range over an 11-speed 11-28 ?
Posted : 26/12/2014 11:03 pm
Bigger gaps is the only downside. If you think you'll make use of it then go nuts!
Posted : 26/12/2014 11:17 pm
Is there really much point in upgrading just for 1 gear difference? After-all, it's not like yer going from say Claris, to Dura Ace...
Why not just splash it on some lighter wheels?
Genuine q, not being an arse..
Posted : 26/12/2014 11:19 pm
Even tho Teetosugars is being an arse, I agree with him. Seems like a bit of a crab move.
...although, the 5800 shifters are flippin' sweet.
Posted : 26/12/2014 11:20 pm
Just had a look and £300 is very cheap for a new 11 speed groupset!
As for gears, I live in the lakes and use an 11/28 cassette (11 speed). I don't often use the 28 though, I only bought this cassette as they had sold out of the 12/25. I do use a compact chainset though.
I would go for a 12/25 since it's nearly a straight through. The bigger the range, the bigger the jumps between the gears (which can be annoying). I rarely use the 11t. I prefer to buy a cassette which is best for the majority of my riding, and just grind up the real steep stuff. Unless you're riding up Hardknott all day, I'd go with a 25.
Posted : 26/12/2014 11:24 pm
But as the OP has a 28 and has been defeated by a climb it seems a 25 is a bit daft!
I do agree though that new wheels would be a vastly better place to put £300. Will virtually get you some Chinese carbon ones.
Posted : 26/12/2014 11:29 pm
😀 whoops, didnt spot that part.
I think my point remains though, I'd prefer to get off and walk up one hill every once in a while, rather than miss the 16t (or whatever it is) that I'd make use of alot.
Posted : 26/12/2014 11:31 pm
I actually prefer bigger gaps, 12/25 10speed gets you nothing from a full sweep of the shifter.
Posted : 26/12/2014 11:33 pm
I'm tempted by the 12-25 cassette, nice single tooth increments all the way up from 12 to 19.
Posted : 26/12/2014 11:34 pm
Already have some nice, light (1395 grams) AR 30 wheels & the reviews of the new 105 set are pretty damn good. Mytholm Steeps has one section approaching 30% apparently - certainly on my Mio page the line goes vertical at that point! I have managed it once with current gearing though so its not that important, more interested in how much improvement there is over my current 10-speed 28 cassette (also with a compact chainset).
Posted : 26/12/2014 11:42 pm
I've not used the new 105, but the 6800 feels good, so if it's similar then the braking and front shfiting will probably feel a touch better than your current setup.
As for the cassette "upgrade" - if you've done the hill once with the 28, then you can do it again. I imagine you don't use the 11t very often, so you could just remove it and stick a 16t in your 10speed cassette to feel the benefits of the extra gear.
Posted : 26/12/2014 11:47 pm
Depends what you mean by improvement. Just buy it and try it. 105 cassettes are only 25 quid so not a huge problem.
Posted : 26/12/2014 11:48 pm
Er, TBH I do use the 11 tooth cog on the flats & descents. Maybe its because its a compact but I find I drop/climb into the tallest gear more often than I thought I would, not saying I use it all the time but it gets used every ride - along with the rest of the cassette.
Maybe I'm doing it all wrong!
Posted : 26/12/2014 11:52 pm
The cassettes are cheap, but you need all the other bits to upgrade to 11 speed!
Posted : 26/12/2014 11:53 pm
It sounds like I'm doing it all wrong tbh! I probably use it once or twice a week if I'm lucky with a tail wind!
Posted : 26/12/2014 11:57 pm
Well, you are in the Lakes, not sure I'd use it much if I lived there.
Posted : 27/12/2014 12:00 am
The purpose of 11 speed is so you can keep the 11-25T close ratios and not need to swap cassettes for the 28T. Shifting will be nicer, but the extra cog isn't such a great deal if you don't already run close spaced blocks. The 10 speed 11-28T so favoured by compact entry level road bikes is a little gappy in the middle.
I run 10 speed 11-23 and 12-25. I also ride fixed and single speed. But when I ride gears, I like them closely spaced 😉
Posted : 27/12/2014 12:03 am
Are your current wheels 11 speed compatible ? If not budget wheels too 🙂
Posted : 27/12/2014 12:07 am
Wheels are 10/11 speed compatible 🙂
Posted : 27/12/2014 9:12 am
