I am with Northwind here.
Always interested to hear different approaches and about different bearings, sadly studied bearings when younger.
We are regularly changing original bearings for us and others, most bearings we pull out fitted originally are corroded on the outside and dried out/rough on the inside.
When re-fitting we always now lift a seal carefully and re-pack the bearings and smear a little grease over the whole bearing before it goes back in.
Only a very few of those we have done need doing again, for most it appears to be doubling/tripling the life.
Our experience is some never need touching, we have never changed a Chris King. But some, bottom headset on Iron Horse Sundays / rear small ones on Stumpjumpers need to be done far too often.
+1 for grease nipples
