Home Forums Bike Forum Giant D Fuse seat post slipping constantly.
Viewing 10 posts - 1 through 10 (of 10 total)
  • Giant D Fuse seat post slipping constantly.
  • renton
    Ive got a 2016 Giant Defy 2 fitted with the carbon D fuse seatpost and Im having issues with it slipping all the time.
    Its the model with a 2 bolt clamp like a normal clamp and Ive done it up correctly but every week its slipping.
    Ive tried cleaning up the post and seat tube but the problem persists.
    Any ideas please.
    Thanks
    Steve
    bigyan
    Are you using carbon assembly paste?
    renton
    No, Is it something that will help?
    daern
    Yes, as well as being anti-seize (something that is *very* important!), it also has some friction material in it (think of it a bit like anti-grease) which makes a huge difference to the amount of grip the clamped frame has on the post. Highly recommended.
    Loads of different ones out there. I happen to use this one and it works for me.
    bigyan
    Yes, it increases the friction between surfaces to prevent slipping on smooth low clamping force joints. It feels like grease with sand in it.
    I use Finish Line Fiber Grip, but loads of options
    renton
    Ok cheers chaps Ive just ordered some !!
    rOcKeTdOg
    use fibre grip grease as normal grease can affect the carbon. carbon to carbon or carbon to alloy with react and weld itself in there making it expensive and possible catastophic to remove
    mtbtomo
    +1 for carbon assembly paste.  It has little grippy blobs in it, works well for me.
    Poopscoop
    I use the not “gritty” carbon paste. Works just as well and doesn’t mark handlebars etc.
    julzm
    Funnily enough I have the same problem although it’s the newer non clamp type (2018 bike). I am using carbon paste but it keeps slipping. It’s going back to LBS tomorrow for something else so will mention to them but it’s a strange one.
The topic ‘Giant D Fuse seat post slipping constantly.’ is closed to new replies.
