Home Forums Bike Forum Genesis io vs Voodoo Wanga
Viewing 40 posts - 1 through 40 (of 58 total)
  • Genesis io vs Voodoo Wanga
  • walla24
    both large, both for ~£170 io is now a sky blue, wanga is red….which shall i buy for my ss build?
    both look mint…cant decide
    julianwilson
    Never ridden either, but one difference ss'ers seem to fret about is that the brake tries to spit the axle out of the back of the non drive side dropout on horizontal dropout/track-ended disc frames. Unless you put the disc mount inside the rear triangle like the newer on one scandal and horizontal dropout inbred. (and another frame which escapes me right now).
    The wanga is clunkier looking than the genesis, but gets the best of both worlds as it has screws to push the dropouts back like trackends but the whole dropout moves (no need to reset the disc brake when you change ratios or the chain wears) and the dropouts are vertical so the axle stays put under heavy braking.
    If it was my money I would save a few pennies more and get a 'new-shape' scandal, or get a brand new inbred and spend the change on some posh chain tugs.
    rOcKeTdOg
    dropouts work brilliantly, no faffing with disc mounts, wheels come out in the conventional way
    mansonsoul
    I'd get the IO personally, though my friend has a wanga, in that red and it is a lovely frame. The extra cable guides for the gears on the Wanga look rubbish when run as a singlespeed and the brake hose guides are rubbish, but it does have a lovely headbadge. It also rides great, if that's important? 🙂
    I have a passionate hatred of top tube mounted cable guides too, so IO everytime for me.
    Mister-P
    Someone on the forum already has a red Wanga and I have not seen a blue iO before so that would make my mind up instantly.
    walla24
    mmm nice rocketdog, take your point about the cable guides tho…
    oxym0r0n
    I got the cableguides taken off the top of my Wanga and it painted blue 😀
    taka
    rocketdog ive just built mine up exactly like that but without the saddle or grips 😛
    ohand i replaced the G with a K now its a voodoo wanka :mrgreen:
    theboatman
    You might find they add a bit of comfort on a long ride.
    walla24
    might get the chance to choose the colour for the io!!!
    candy apple green or cherry red????
    taka
    LOL at theboatman
    marty
    i've had both.
    wanga[/url]
    io[/url]
    both been fine bikes. i fell out with the wanga early on when i threaded one of the sliding drops snugging it up on a long ride. made it home OK, but it needed new sliders.
    io's track ends + avid bb7 are no bother even with a qr in the hub (with chain tug on the d/s) – wheel removal doesn't need the caliper to be moved.
    which one is the nicer colour? 🙂
    epicyclo
    Both good bikes.
    The io is the simpler and handles well. The Wanga has the convenience of the sliding dropouts.
    Buy both!
    codebauer
    Which posh chain tugs?
    walla24
    i like simple, and good handling, and poss being able to choose colour…so io wins.
    question though, are chaintugs optional? i dont really understand
    julianwilson
    you won't need chaintugs with the io as it has bolts built in through the dropouts to push the axle back against the tension of the chain. (I mentioned chaintugs earier cos you would benefit from them to singlespeed an on-one. Sorry if i confused things.)
    taka
    like thease
    walla24
    ah i get you now…foray into the world of ss, loads of new things to learn!
    bent_udder
    I've got an Io, and it's a lovely bike.
    The problem mentioned above with track ends and disc brakes and rearward movement is easily solved – tighten the locknuts on the rear hub properly. 🙂
    there are also thumbscrews on the Io to adjust the chainline – quite neat.
    Personally, I think you'll get a good bike whichever frame you buy. I'd probably get a Wanga if I wanted to switch between gears and SS, but if you don't want to do that, the Io would win every time for simplicity's sake.
    walla24
    for the io il be needing a bolt thru hub then? does anyone know what size?
    hungrymonkey
    Io is a lovely bike to ride, but the track ends contributed greatly to my reasons for selling. imo/ime they're a PITA compared to sliding dropouts, which are just great to use – one chain tension set up, and just drop the wheel in and out as usual. Io needs it adjusting every time i took the wheel out, and the caliper (XT) got in the way, and would need loosening each time too. comlete faff to do, and spoiled my experience of the bike.
    out of those, despite not particularly liking the voodoo, i would get the voodoo, with the Io's track ends
    hungrymonkey
    out of those, despite not particularly liking the voodoo, i would get the voodoo, with the Io's track ends being the sole reason.
    walla24
    hmm slightly cold feet on the io now,
    so when ever i need to remove the rear wheel (ie when i load up the car/addictively change tyres) i would have to loosen/reset the brake calliper? and there are complaints of having the axle move under heavy braking?
    that does sound massively annoying…oh no cant decide again.
    Any other suggestions for a frame?
    rOcKeTdOg
    kona unit (exactly the same dropout system as the voodoo) or something with an eccentric BB?
    james-o
    "The problem mentioned above with track ends and disc brakes and rearward movement is easily solved – tighten the locknuts on the rear hub properly"
    yeah we were aware that disc forces can cause the axle to shift in theory but in reality it only happened under hard braking if we didn't do the bolts up very tight at all. a tester got it to shift by doing trials-style lunges against the brake onto a small stump, but apart from that it's been issue-free and our resident team rider / ss nutter Paul has had no issues while riding 3 or 4 x what i could manage in a very busy year )
    walla24, no need for a bolt-thru hub as in 12mm stds, just a solid 10mm axle with nuts or bolts i/o a QR axle. most if not all SS hubs have this now.
    james-o
    "so when ever i need to remove the rear wheel (ie when i load up the car/addictively change tyres) i would have to loosen/reset the brake calliper?"
    not always, it just needs setting in a position that allows the brake rotor out – this varies between brake models so some adjustment is needed. mine pops out fine, its a std spec 2010 bike.
    SS and discs can be a minor hassle whatever you go for, creaking or less-than-stiff adjustable parts are the risk with other systems. we went with solid and simple, on the basis that if wheel removal needs to be racer-fast you're probably not considering a SS in the first place )
    james-o
    "and there are complaints of having the axle move under heavy braking?"
    in theory, like in theory your front wheel can eject but in reality does it happen? i like simple…
    marty's post is worth reading again )
    TandemJeremy
    I have a Genesis io id. The rear wheel has been solid so far. Its a bit of a faff to remove – but once set you don't need to touch the brake caliper until the chain tension changes dramatically – removing the wheel is easy without touching the brake – and it will go back to the same position as the position of the wheel is dictated by the chain length.
    Its a PITA as you have to back off the screws that push the wheel back to get enough slack to get the chain off before removing the wheel
    Edit – I do like having those screws tho – it means the wheel can't move forward/ out of line under pedalling pressure
    james-o
    TJ, i know what you mean, i use the screws on one side just to set wheel position on the disc side, and back them off on the drive side to allow this bit of slack. i find you only need a touch of slack to be able to ping the chain over the c/ring and derail it. looking into some wing-nut style bolts to make this easier, when we get them we'll have spares as retro-fit parts.
    slowjo
    I had a Wanga, nice bike but I found the head angle a bit steep (for my liking). As far as the dropouts were concerned they were idiot proof. Another gripe was the ease with which the paint chipped… but it wasn't that much of a gripe.
    walla24
    right re-read all the posts, back on track for an io.
    yeah fair enough like most things it takes a bit of adjustment but once set up its sorted.
    I think i'l understand it more when i can have a look/fiddle
    cheers all, will wait to hear back from the seller
    marty
    this is where a chaintug works better IMHO. could leave in the nds one to prevent any braking movement, but i've not experienced this yet.
    TandemJeremy
    james-o – Member
    Thats how I do it as well – thumb wheels would be better that wing nuts IMO
    The bolt on the brake disc side is ver difficult to get an allan key on if needed
    However I am impressed with the bike in general – rides nicely, reasonably light nice cable routing
    binners
    I've got a Wanga. Its lurverly. The main advantage is that when you come to your senses, you can just put some gears on it. Bonus!
    FieldMarshall
    Have had an IO for a year now and been running it fine with a QR rear axle.
    Never had to slacken the "thumbscrews" to get the wheel out. (Maybe people are running their chains too tight?)
    I just derail the chain off the chainring, pop it off the rear sprocket and hey presto it slides out easy as pie.
    Getting the wheel out of the caliper can be a bit tight, but have managed to find a chainlength (with help of a half link) that means it comes out fairly easily.
    Never had to adjust the caliper either.
    Really like the "thumbscrews", so easy to set up the wheel alignment and allows for really precise micro tweaking of chainline and of rotor within caliper. Much easier than the sliding drop outs in my P7.
    However, sliding dropouts do give you a geared option.
    In terms of ride, I find IO is a bit harsher than other more expsensive steel hardtails I jave ridden, but still a great bike for the money.
    FieldMarshall
    FieldMarshall
    Apologies for double post – pc froze and so refreshed.
    Curious to know where you can get an io frame in sky blue for £170?
    HTTP404
    Not a big fan of the slidey mounts on the voodoo. They're not the prettiest to look at but work really well. Would have thought the The voodoo is 631 steel (main tubes) and the Io 725. Not sure how that translates into ride so perhaps try and scrounge a test ride before hand.
    Learn to fix punctures on the wheel?
    james-o
    "The voodoo is 631 steel (main tubes) and the Io 725. Not sure how that translates into ride so perhaps try and scrounge a test ride before hand."
    the iO is 520 now, we didn't really need the strength of 725 and wanted to keep the cost down.
    The ride of 631, 725, 520 etc is the same for a given tubeset dimensions, so it's not necessarily the case that expensive steel equals a better ride, it depends what they've done with it. you can go thinner wall / slimmer tubes with the stronger stuff, but then denting and excess flex can be an issue.. but yes, a test ride is always good 🙂
    james-o
    TJ, yes like Paul Component style, it's the way to do it, i thought wingnuts may be easier with mud and gloves though? finding them in the right size to try out is another issue though..
The topic ‘Genesis io vs Voodoo Wanga’ is closed to new replies.
