Home Forums Chat Forum Garage floor – interlocking floor tiles – experiences?
  • This topic has 13 replies, 13 voices, and was last updated 2 years ago by diz.
Viewing 14 posts - 1 through 14 (of 14 total)
  • Garage floor – interlocking floor tiles – experiences?
  • stevious
    Our new house has carpet in the garage and I do not wich to even contemplate what a mixture of turbo training and bike maintenance will do to it.
    In my last place I put down an epoxy floor, which was great but a bit of a faff so I’m thinking of getting those interlocking tiles. SOmething like this: https://garagefloorsdirect.co.uk/product/duraflex-tile-garage-floor-mat-black-60-pack/
    How easy are they to install and once in what’s the durability like? Any other experiences of such flooring (or suggestions for alternatives)?
    Thanks!
    dovebiker
    For cheap’n’cheerful, Halfords EVA tiles are OK, but are a soft foam so not suitable for high wear – I have them in my business workshop. Just built another shed as my bike workshop/ static bike trainer – have used the Big Dug garage floor tiles – made from recycled PVC are far more durable/hard wearing
    olly2097
    I’ve had them in the garage for years. They’ve been fine. Got them as insulation under the summerhouse floor as well.
    TiRed
    BigDug floor in mine. It’s fabulous and was worth every penny. Fitting with a rubber mallet was simple and fun. I have a black/grey check to break up the black, with a 2×4 patch in Wahoo Blue.
    bigyan
    The hard plastic ones I have (Plasfloor) have been good and hard wearing (as long as they are on a hard flat surface, eg smooth concrete) Easy to install, just a lot of joints to line up and click in.
    The soft foam ones are good for yoga etc, but not a garage floor (for my use).
    jimdubleyou
    I’ve got duramat tiles – can’t fault it.
    Actually got blue ones for the same price as black which looks pretty good.
    richardkennerley
    Bigdug in mine. Sweep floor, bang tiles down, job done in less than an hour 👌
    stevious
    Thanks all. Am definitely sold on the idea of using a rubber mallett to install. Awesome.
    Superficial
    I could have written almost exactly this. It makes the garage seem warmer and it’s nicer to kneel for maintenance jobs.
    oldmanmtb2
    Used the Halfords ones (very cheap when on offer) bit soft but great to walk and work on…
    theotherjonv
    I’ve had the Halfords ones for years, can’t really fault them for what I paid and how long they’ve lasted, but here goes.
    1/ over time they’ve expanded, IDK if that’s as a result of all the standing and walking on that’s been done, or whether the odd solvent spillage (white spirit, or Screwfix No-nonsense) has swelled them but means they now are not a perfect fit and pucker a bit. Which leads to
    2/ although I shove them back down as best I can the interlocks are not tight and where it’s not a clean garage muck and dust gets in the gaps which is a pain to have to lift the edges to hoover out
    Like I say, for the cost I should just bin them and get a new set and they’ll be grand for a couple of years at least but instead I bought an Amazon barrier mat which sits over the foam mats – not thick enough to be able to work out there barefoot so it’s over the foam mats but has no gaps, and can be easily lifted and taken out the front with a whacker every now and then to clean it off. And I’m more careful now with solvents too.
    martinhutch
    Another BigDug user – very, very easy to cut to fit, even around existing workbench legs etc. Feels warm underfoot. Not sure about durability yet, will probably get another cheap mat to protect ‘high drip’ areas.
    fazzini
    If you have a perfectly square/rectangular garage with nothing permanently fitted like workbench etc. I dream of one day having such a set-up 🤣
    diz
    Hi has anyone any experience of parking a vehicle on the floor tiles? Bigdug or any other type?
