Home Forums Bike Forum Frame bungs for internal routing – help!
Viewing 10 posts - 1 through 10 (of 10 total)
  • Frame bungs for internal routing – help!
  • letmetalktomark
    I have a frame that uses internal routing.
    I have decided to try routing the cables externally using frame mounts and p clips less for aesthetics more for kinder cable/house routing.
    The “thing” is that this will leave 5(?) holes needing plugging 🙄
    The manufacturer does stock spare bungs 😐 and have suggested I leave the open.
    That’s all fine and dandy but I would like to plug them.
    Any suggestions?
    Frame is a Giant BTW.
    Slogo
    I would use the brake and gear cables.
    Electrical tape? a sticker, silicone sealant.
    Northwind
    Orange sell plugs but no guarantee they’ll fit. If they’re round holes on flattish surfaces there’s likely to be household alternatives, a wee ebay search will probably find something
    Think I’d be tempted to use a tidily cut bit of tape tbh. But not a sticker because you might mistake it for a crack.
    lunge
    Silicone sealant if it’s a white frame maybe?
    andyl
    Sugru
    scruff9252
    Could fill the holes with molten lead?
    monkeychild
    Why go external???
    rp16v
    Which frame is it as quite a few have internal routing now id get the correct plugs myself
    coatesy
    Blanking grommets, often sold for electrical/electronic work. Try RS Components or Maplins, or maybe just google it.
    steve_b77
    I used the end cap off a biro, fitted the hole perfectly and has stayed in so for
The topic ‘Frame bungs for internal routing – help!’ is closed to new replies.
