Motorex 2.5wt or any quality 15 cSt fluid in the damper. Supergliss or 20wt gold in the lowers.
There is no reason to use a teflon infused oil and no reason to use the same oil in the damper and bath. These forks don’t suffer any more or less oil mixing than other cartridge forks and a little oil mixing (bath oil into the damper, damper oil in the bath) is no big deal.
This is the advice from Dougal who runs Shockcraft in NZ.
I imagine he’s right about the limited mixing. As I understand it, it’s a self bleeding damper rather than an open cycling type. In which case, what he says about a heavier oil in the lowers makes a lot of sense. The Supergliss 100 he mentions is fantastic in the lowers.
