Home Forums Bike Forum Fitting a shimano crank arm to campag bb
Viewing 8 posts - 1 through 8 (of 8 total)
  • Fitting a shimano crank arm to campag bb
  • soma_rich
    Is it possible to fit a Shimano square taper crank arm to a campag bb?
    cynic-al
    I can’t remember which way round isn’t meant to work, tho I think I have seen both work!
    I think this way is OK. Someone may correct me
    mattsccm
    It will go. Either way. Tapers don’t match but WTF. Dog it up tight and keep an eye on it. After a bit the steel BB shaft will make its own taper in an alloy crank.
    soma_rich
    Mattsccm that’s what I thought. Thanks guys,!
    Have you found an arm rich?
    Just about to go and have a good dig in the garage 🙂
    oldgit
    It goes but it’s not great. JIS and the other one.
    slinkybike
    Campag is Iso shimano jis i have been trained not to mix the two as your likely to shagg the crank arms.
The topic ‘Fitting a shimano crank arm to campag bb’ is closed to new replies.
