Home Forums Chat Forum First world car problems #3
Viewing 20 posts - 1 through 20 (of 20 total)
  • First world car problems #3
  • 1
    reeksy
    To get the back seats down in my Alfa there’s a lever on either side under the rear seat*.
    The lever operates a cable that releases the latch… well it did. On both sides the cable no longer works.
    I’ve pulled up the seat base and can see that the plastic bracket designed to hold the outer cable in place while the inner cable does its work has broken away from the plastic seat base frame.
    IMG_9070
    I’d really like to get these working again because we’re putting things in and out of the boot from inside the car every time we use it due to the bike rack.
    Ideally a metal bracket attached somehow would work, but I don’t want to mess up the seat frame by putting screws into it.
    Any ideas?
    *there’s other levers in the boot that you can reach but it’s a pain from the back seat.
    dooosuk
    Buy a new plastic bracket.
    reeksy
    Sadly it was part of the moulded plastic frame so not replaceable.
    thepurist
    What size is the inner/outer cable? You might be able to replace the mechanism with a dropper post lever which you can then fit where you want.
    FuzzyWuzzy
    Is it the left side of the cable holder bit is supposed to sit against the side of the right side plastic piece? If so there looks enough room to wrap some reasonably thick wire around it (and twist on tightly with pliers). Maybe with a bit of super glue for good measure?
    tthew
    I think you hit the nail on the head with your screwed in metal bracket. Couple of stumpy little self tapping screws, they’ll be well hidden surely? Just gluing the original ones back in place unlikely to work if the moulded bits aren’t strong enough.
    5lab
    Part of the plastic frame of what? You’ll probably find an entire rear bench seat from an old car like that is £50 or so. Easier than faffing with a small part.
    bigdugsbaws
    Original part with a ton of JB Weld to reinforce it
    1
    timba
    It’s an Alfa, the plastic has either rusted or developed an electrical fault
    If you don’t want to use screws then presumably rivets are out of the question?
    That leaves either adhesive* with lots of scuffing of the plastic and building up a reinforcing fillet or a dangly bit of cable that you pull.
    * https://express-paints.co.uk/starchem-rigid-plastic-2-pack-adhesive-50ml/ A car body shop might have a plastics welder, dunno how strong that would be in this application
    Can you re-route something from the boot pull to the interior?
    2
    Kryton57
    New car time.  Ideally in excess of £40k.
    reeksy
    The entire seat base frame. Sadly it’s in the infamous “40 grand category” of car but definitely not worth the money or effort of replacing for something that will do the same again.
    Screwing something on from the inside will likely leave screws poking through the leather in a nasty spot.
    redthunder
    Rusty plastic.
    Looks like a Hack/Bodge problem to me.
    reeksy
    The photo is from above with the seat base removed. The cable would be under the right arse cheek drivers side. The bracket has come away from the right side. In the photo the bracket has turned 90 degrees.
    Putting the seat base back in was a pig of a job due to getting the seat belt receivers through the holes.
    sockpuppet
    Using a dropper post cable and remote to solve a bike rack related access problem would be most pleasing
    reeksy
    Yeah… But not really in keeping with keeping it stealthy.
    intheborders
    How did it break in the first place, crap design/materials or <user error>?
    This ought to determine how to fix it – if the latter then get replacement parts, if the former then something new.
    multi21
    inthebordersFree Member
    How did it break in the first place, crap design/materials or you <user error>?
    Or has the latch that its (supposed to be) releasing lost its grease?
    reeksy
    Poor design and materials. Exacerbated by lots of use.
    A similar thing happened with the bonnet pull. I was able to fix and improve that with a cable tie to stop it popping out again.
    1
    desperatebicycle
     lots of use… similar thing happened with the bonnet pull.
    True what they say about those pretty Alfas then?
    reeksy
    Pretty **** annoying?
